keefe007
Graph Packets Per Second
Tue Jan 15, 2008 2:53 am
Is there a way to graph packets per second using SNMP?
ahmedsaffar76
Re: Graph Packets Per Second
Sat Mar 08, 2008 12:09 am
Hi ;
I think this is impossible for many reasons like that it will consume the cpu and the routers resources and you don't need a graph for each second .
you could open the graph of any interface or client , it will show you a live graph and if you need to read a point on the graph simply point the mouse on it and hold the left click and it will give you the speed details and the time .
also you could activate the graphs for the interfaces and clients from tools -> graphing and do the same as above on the graphs .
with best regards .
:D
GuJack20
Trainer
Trainer
Sat Mar 08, 2008 12:23 am
For sure you can do it.
I prefer Cacti. You can configure a Centos Server with Cacti and there are also nice templates for RouterOS.
--Do you remember that guy who gave up? Neither does anybody else!
gustkiller
Sat Mar 08, 2008 6:00 am
whats the oid for pps?
keefe007
Sat Mar 08, 2008 8:12 am
Or which exact canopy template has this?
ahmedsaffar76
Sat Mar 08, 2008 11:48 am
Hi ;
Thanks for your reply .
Kindly could you give us details about this centos server with Cacti ? do i have to install them in MikroTik or in another pc ?
waiting your feedback .
with best regards .
dssmiktik
Forum Veteran
Forum Veteran
Thu Apr 09, 2009 4:25 am
I was able to graph PPS by creating a Data Source from OID (i used snmpwalk)
1.3.6.1.2.1.2.2.1.11 (ifInUcastPkts) then .1 for first interface, .2 second, etc..
then create a chart graphing from those data sources.
The big downside I can see with this is that you have to add each and every interface on each and every device as a separate data source. I don't know of a way to "collect" and auto-create these data sources. Also, I'm still not finding the equivalent of
/interface monitor-traffic aggregate info in SNMP for Mikrotik.
Hopefully I'm missing something and there's a better way to do this.
Doug
Doug
changeip
Thu Apr 09, 2009 6:15 am
/interface> print oid
0 R name=.1.3.6.1.2.1.2.2.1.2.1 mtu=.1.3.6.1.2.1.2.2.1.4.1
mac-address=.1.3.6.1.2.1.2.2.1.6.1 admin-status=.1.3.6.1.2.1.2.2.1.7.1
oper-status=.1.3.6.1.2.1.2.2.1.8.1 bytes-in=.1.3.6.1.2.1.2.2.1.10.1
packets-in=.1.3.6.1.2.1.2.2.1.11.1 discards-in=.1.3.6.1.2.1.2.2.1.13.1
errors-in=.1.3.6.1.2.1.2.2.1.14.1 bytes-out=.1.3.6.1.2.1.2.2.1.16.1
packets-out=.1.3.6.1.2.1.2.2.1.17.1
discards-out=.1.3.6.1.2.1.2.2.1.19.1
errors-out=.1.3.6.1.2.1.2.2.1.20.1
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Users browsing this forum: MSN [Bot] and 33 guests
