Ibersystems
RS232 question
Thu Jan 17, 2008 2:29 pm
I need to control devices in remote. My LAN is at point 0m and my devides are at a distance of 1km. My devices only have an RS232 connector. Can I make a point to point with 2 mikrotik and control devices directly from RS232 of mikrotiks? or I have to put another device to convert ethernet to RS232? I have to pass signals to switch on/off electrical devices
Thanks,
Martín.
JJCinAZ
Re: RS232 question
Fri Jan 18, 2008 12:00 am
Depending on your needs, you might be able to use the special user feature in ROS where you can designate that when a specific user connects to the router with telnet or ssh, they will get connected through, immediately, to the RS232 port. Check the docs for details.
SurferTim
Re: RS232 question
Fri Jan 18, 2008 1:14 pm
Greetings!
Need to turn on and off electrical devices on the net? I use the Rabbit Semiconductor products. Connect and access like any IP device, except it is designed for exactly what you want to do. You will need some electronic experience to assemble your working product. It comes as a "core module" with a bunch of TTL compatible pins, but the rest you must construct. That is no problem here.
The RCM2100 is the one I use. Has web server, form processor, etc onboard. The smallest web server I have seen so far! Smaller than a credit card.
They also have products that convert ethernet to RS232 format, but I have not used those.
http://www.rabbit.com
I think this answer (not your question) may be off-topic for this forum, tho...
I am in no way connected with Rabbit Semiconductors. I just like their products. :D
Ibersystems
Re: RS232 question
Fri Jan 18, 2008 1:51 pm
Thanks!
I'll study the 2 solutions.
Martín
JJCinAZ
Re: RS232 question
Fri Jan 18, 2008 5:43 pm
For simple power control over Ethernet, try these products: http://www.controlbyweb.com/webrelay/index.html
lahoras
Re: RS232 question
Mon Feb 04, 2008 6:40 pm
This is another compac solution, http://www.tibbo.com/products/, it was help me too much, becouse is a transparent rs-232 over ethernet link, i hope help you....
ARIEL
Mtshepisto
Re: RS232 question
Mon Mar 24, 2008 3:46 pm
Hi, I have the same problem, I looked at the serial to ethernet adapters and they can work. Tell me, were you able to use the serial module of the board or did you opt for the adapters?
Mactrekr
Re: RS232 question
Sun Mar 30, 2008 6:14 pm
A more advanced solution to this is to use a product by a company called netburner. We have successfully set up a remotely operated dual camera pan tilt system with this. We are able to control all functions of both RS232 cameras and RS232 pan/tilt head from anywhere in the world. It would be really nice if a RB133c could do this though.
Mac
phendry
Re: RS232 question
Wed May 21, 2008 4:07 pm
Anyone know if Mikrotik are planning to make the builtin serial port usable for this kind of thing?
johnsonwc
Re: RS232 question
Thu May 22, 2008 4:43 pm
All,
I need to control a Iridium modem through the serial port. As far as I can see, ROS is sadly lacking in serial capabilities making this a very difficult task. JJCinAZ mentioned some "the special user feature in ROS where you can designate that when a specific user connects to the router with telnet or ssh, they will get connected through, immediately, to the RS232 port." I'm not aware of this special capability. Can someone clue me in, or if you have any ideas you would like to share, I'd like to hear them.
Thanks,
Walt
Users browsing this forum: Google [Bot] and 32 guests
