ncrossley
AP Setup Problems.
Fri Jan 18, 2008 7:14 pm
1 X Omni Directional 900mhz
1 X XR9 Wireless Radio/8 port MiniPCI/PCI adapter
1 X x86 1.3Ghz based routeros system
12X RB133C3/XR9 Combo Client units
Configuration is as follows.
AP Configuration: G Mode
The AP is fed from a 10mbit dedicated connection Hardwired into the LAN port.
Created a Bridge interface while in AP Bridge mode.STP Enabled. Ether1 as only port.
Set to Dynamic WDS.
IP Address of the Bridge/AP is 192.168.200.20 /16 subnet
12 Client units connecting to AP Unit.
Average signal of -75
Client Side Config
Created Bridge. STP enabled. Ether1 and Wlan1 as the ports.
IP Address set 192.168.200.21-33 /16 subnet
Connections stay stable but speed varies from 18kbps -> 7mbps
seems the more clients I add the worse it gets. Any ideas guys?
jwcn
Re: AP Setup Problems.
Sat Jan 19, 2008 5:21 am
Do research on RF. You really need to.
Start by switching to 5mhz spacing.
ncrossley
Sun Jan 20, 2008 9:47 pm
Up to about 10 clients I am perfectly fine, everyone stable around 5mbit with bursts up to 12mbit or so.
Problem really starts being noticeable at client 12/13 and exponentially worse with every device I add after that.
Does not only hurt the new user but all users suffer from the speed loss.
Shouldn't it only be the new user being slow if it is a problem with their installation?
jwcn
Sun Jan 20, 2008 10:26 pm
Where are you located?
ncrossley
Mon Jan 21, 2008 2:30 pm
Canada
jwcn
Mon Jan 21, 2008 4:01 pm
Rumor has it there is enormous Canopy use in Canada. You won't survive unless you learn to work around the RF interference. Using these radios in "g" mode will do nothing but take you down.
ncrossley
Mon Jan 21, 2008 5:09 pm
So best bet would be drop down to 2ghz 5mhz?
jwcn
Mon Jan 21, 2008 7:48 pm
Well here's the deal. With compression on you can push about 5megs aggregate on the SR9's at 5mhz. The nice side of 5mhz is you have a lot more flexibility to move around interference.
I've personally given up using the SR9/XR9 systems because they don't coexist well with Canopy but thats all I can say in the venue...
ncrossley
Mon Jan 21, 2008 8:34 pm
Thanks for everything, will do some more research as well.
Users browsing this forum: Google [Bot] and 40 guests
