MUM Europe 2020
seluwole
How do i use MT with External Radius Server
Tue Jan 22, 2008 11:21 am
Can anyone give me a detailed guard lines to setup Mikrotik to use an external Radius Server.
Such that all user information will be on my Radius Server not that the radius server is also my current DNS server.
Ellis.
SurferTim
Re: How do i use MT with External Radius Server
Tue Jan 22, 2008 12:23 pm
Greetings!
Add the MT hotspot IP and radius secret to your radius server client file.
Adjust your radius server firewall to pass ports 1812 and 1813 from that IP.
I use the CLI, so on the MT box:
/radius add service=hotspot address=xxx.xxx.xxx.xxx secret=radiussecret
/ip hotspot profile set X use-radius=yes
Change xxx.xxx.xxx.xxx and radiussecret to your radius server and radius secret.
Change X to the item number of your hotspot profile. You can see that with
/ip hotspot profile print
Then give it a try.
Just a note: If you want to use any time-based RADIUS features, insure to set your MT box for NTP. Otherwise the clock resets to jan/01/2000 00:00:00 on power fail or reboot.
winagain
Tue Jan 22, 2008 1:24 pm
Greetings!
/radius add service=ppp address=(is this the main radius server) .....
SurferTim
Tue Jan 22, 2008 3:09 pm
My setup does not require the ppp setting. Only what I listed. If your setup requires it, then that is where it would be added.
winagain
Tue Jan 22, 2008 4:02 pm
thanks, will give it a try!
seluwole
Wed Jan 23, 2008 9:30 am
Thanks for the kind response it works just fine.
Pepo
Sat Aug 23, 2008 8:57 am
please give me pictures for that solution
:lol:
reta
Thu Apr 14, 2011 9:44 am
hi
I configure windows server 2008 to work as a radius server but when connect it to MT its not work and the it give me "RADIUS server is not responding" what is the problem ?
Beone
Thu Apr 14, 2011 9:57 am
hi
The problem is your radius is not responding :-) !!! If the radius ip is set correctly in MT, it should respond.
But are you sure your radius is setup/working correctly? Is your MT configured as a client in your radius config?
Test your radius with NTRadPing or similar.(don't forget to add the pc where you run the test utility from as a client too!)
Radius on windows makes me shiver anyway.... Try linux with freeeradius, you'll sleep better :-)
Good luck
B
Users browsing this forum: Bing [Bot] and 57 guests
