mangust
mac-telnet from Linux Box
Tue Jan 29, 2008 4:38 pm
Is it possible?
How i can do that?
janisk
Re: mac-telnet from Linux Box
Tue Jan 29, 2008 4:56 pm
this is not possible as there is no such software available for linux
only thing that is possible is to connect to router and the from that router connect to your other routeres using mac-telnet (the way i do that myself)
darkmachine
Sat May 10, 2008 2:55 am
Neighbor viewer, downloadable from the the Mikrotik website, has MAC-telnet, only for windows. I run linux, so I use Wine. This works perfectly. Under Ubuntu
sudo apt-get install wine
give it a try
secret
Mon Oct 12, 2009 3:48 pm
I have two network cards on my box. The mac telnet utility tries to connect using the wrong card network.
Is there a command line or way to bind the mac telnet to the correct card?
The neighbor viewer utility sees the neighbor but the mac telnet doesn't work because of the two cards...
haakon
Sat Oct 02, 2010 3:31 pm
As this is a answer to an old post, this is just for future references:
You could either use Wine to run MikroTik's own windows tools in Linux.
Or you could try out my open source Mac-Telnet application for linux:
http://github.com/haakonnessjoen/MAC-Telnet
Håkon Nessjøen
<haakon.nessjoen[a]gmail.com>
savage
Thu Apr 05, 2012 1:00 pm
*very* interested in this.... But
RHEL4:
cc -Wall -c interfaces.c
cc -Wall -c protocol.c
protocol.c: In function `parse_mndp':
protocol.c:369: warning: implicit declaration of function `le32toh'
cc -Wall -o macping macping.c interfaces.o protocol.o
protocol.o(.text+0x964): In function `parse_mndp':
: undefined reference to `le32toh'
collect2: ld returned 1 exit status
make: *** [macping] Error 1
#include <byteswap.h>
#define htole32(x)      (bswap_32(htonl(x)))
#define le32toh(x)      (ntohl(bswap_32(x)))
in protocol.c and mactelnet.c sorted out le32toh. But mactelnet.c still errors...
mactelnet.c: In function `send_auth':
mactelnet.c:193: warning: implicit declaration of function `htole16'
/tmp/ccyZiFO3.o(.text+0x4ad): In function `send_auth':
: undefined reference to `htole16'
/tmp/ccyZiFO3.o(.text+0x4c5): In function `send_auth':
/tmp/ccyZiFO3.o(.text+0x5a3): In function `sig_winch':
/tmp/ccyZiFO3.o(.text+0x5b5): In function `sig_winch':
Chris
Regards,
Chris
defaulttrue
Sun Dec 02, 2012 3:23 pm
just add another "#define htole16(x) (bswap_16(htonl(x)))"
and do "make mactelnet"
./mactelnet <MAC>
pikpik
Thu Dec 13, 2012 5:56 pm
Ivoshiee
Mon Jan 07, 2013 3:00 pm
Are you developer of that code?
luqasz
Sat Apr 26, 2014 2:20 am
https://github.com/haakonnessjoen/MAC-Telnet
under debian and ubuntu just:
apt-get install mactelnet-client
plisken
Sat Apr 26, 2014 9:05 am
I have also troubles with winbox, i have wine installed and winbox works on it but the mac coms not if i click on the three dots.
In windows works that fine.
Please make a winbox on Linux this shal us help.
Users browsing this forum: Google [Bot] and 109 guests
