MUM Europe 2020
technalogic
mac address spoofing problem on network
Wed Jan 30, 2008 8:47 pm
Hi i am using mt router os for authentication i also bind mac address on login id
but some clients spoofing other clients mac address and he is using other clients bandwidth and my dhcp server also leases same ip are both clients please help me. :(
i am using router os 2.9.27
ram
Re: mac address spoofing problem on network
Thu Jan 31, 2008 11:46 pm
I have the same problem but it seems that no one has a solution for this isue and no one say if this is a bug or loss of setting...
only one says upgrade to version 3.1 router os.....
I don't know why no one want to talk about this....
I only want to know if there is a solution for this or not...
this the link of my post http://forum.mikrotik.com/viewtopic.php?f=2&t=21457
pedja
Long time Member
Long time Member
Sat Feb 02, 2008 10:04 am
It is quite simple, when you use 2.9.27 it is highly suspicious that you are running cracked version, so, people are less willing to help.
The actual problem is that you are trying to use technology you do not understand well. What you have as a problem is very basic thing: you relay on MAC addresses and MAC addresses may be spoofed. This has nothing to do with MT, it cannot see if reported MAC is real physical MAC or spoofed one.
What you have to do, is to set hotspot or VPN or think up some other way to authenticate user which requires him to type in his password to gain access.
Users browsing this forum: No registered users and 25 guests
