el berto
Linux on routerboard?
Wed Feb 06, 2008 4:04 pm
Hi, I have a RB333 and I would like to know if possible install linux.
I need more powerfull scripts (I'm actually using these scripts on a desktop linux pc, but I would install it on a routerboard) so I can manage directly storage devices through serial port, send data, etc. etc.
Is it possible?
Are there available drivers to use R52 radios on linux?
csickles
Re: Linux on routerboard?
Wed Feb 06, 2008 6:57 pm
Take a look over at http://www.routerboard.com
The forums there deal with Linux on routeboard.
I dont know if there is a distro for the RB333, I would asume there was as RouterOS is a Linus Kernal...
Also check the product page for the 333, I know on the 500 series page it has links to installa disto...
Things that make you go "Hmmmmmmmm"...
Craig
normis
Thu Feb 07, 2008 10:22 am
forum.routerboard.com has more info, but remember that it's not easy and you will have to patch the kernel
Users browsing this forum: No registered users and 28 guests
