quebeker
hotspot setup ok, how to change login page
Tue Mar 04, 2008 5:48 am
I set up the hotspot on ether 5 of a RB 150 and when I surf on that ap it brings me to the Mikrotik login page.
I would like to have a page with a message about who to call for service, rates etc.
Can someone tell me the easiest way to do that
thanks
ashish
Long time Member
Long time Member
Re: hotspot setup ok, how to change login page
Tue Mar 04, 2008 5:55 am
you will find <login.html> in the Hotspot Directory under /file menu.
Download the file and Design it according to your requirement.
quebeker
Tue Mar 04, 2008 6:39 am
I see the file Ashish but how to I download it. When I double click it just highlights.
thank you very much
ashish
Long time Member
Long time Member
Tue Mar 04, 2008 9:38 am
connect the router Via FTP.
You will find the Hotspot folder and <login.html> in it.
Copy it to your local computer. After Doing changes the same way you can upload the file.
If you login thru WINBOX, Just drag the file drop in to desktop.
ahmedsaffar76
Wed Mar 05, 2008 1:59 am
Thanks Ashish ;
this method more easy to use .
with best regards .
Users browsing this forum: PBondurant and 26 guests
