MUM Europe 2020
titius
UPNP over multiple broadcast domains
Tue Mar 11, 2008 2:28 am
I set up UPNP on internet gateway mikrotik, and it works fine with clients that are in same broadcast domains, but its not working with client on another subnet .. .
Is it possibile to acomplish or it cant be done ?
titius
Re: UPNP over multiple broadcast domains
Wed Mar 12, 2008 11:36 am
somebody ?
titius
Fri Mar 14, 2008 4:05 pm
please :( :) .
titius
Tue Mar 18, 2008 2:44 am
Please, is this not a beginner Q?
Im trying to set UPNP to work over multiple subnets, that have one def gateway to the internet, so I dont have to manually forward ports to users on the gateway MT, I want UPNP to do that :) .
titius
Wed Mar 19, 2008 3:49 am
pleeeease :) .
normis
Wed Mar 19, 2008 9:37 am
but the main idea of upnp is to add automatic nat rule. there is no use for that if the machine is not directly connected to the same network ...
titius
Thu Mar 20, 2008 1:13 pm
yes, idea is to add dst-nat rule.
So I thought it can do that for computers that are not directly connected to that network.
But ok, thx for the answer, so I dont bother me and you with UPNP :) .
Users browsing this forum: Alexdv and 53 guests
