xezen
Long time Member
Long time Member
mikrotik wake on lan!
Sat May 31, 2008 12:39 pm
can mikrotik be setup up so that when i ping is or us a program
to start it up
after a shutdown
If i dont No Ask someone That Does!
normis
Re: mikrotik wake on lan!
Mon Jun 02, 2008 1:56 pm
no. what kind of router is this, that is offline most of the time?
also - i think that is the feature of BIOS (motherboard), not RouterOS.
mushmx
Wed Mar 11, 2009 5:31 pm
Well I am disagree because I have installed RouterOS over PC.
For example, sometime the power electric is off for long time and the battery backup is discharged for the same reason "long time without power electric". If the Wake On Lan option is will add to RouterOS I could turn on the PC from my MKT 511 when the power electric come back.
Best regard.
pedja
Long time Member
Long time Member
Wed Mar 11, 2009 6:03 pm
Althrough I support your request as usable, I would suggest to use PC motherboard that has BIOS option to turn on automaticaly on power. If BIOS does not have such option, you may also make some simple hardware to make it turn on when power comes (simulate power on button pressed), but that hardware depends on motherboard.
rmichael
Forum Veteran
Forum Veteran
Thu Mar 12, 2009 1:51 am
Best regard.
What you're describing is not Wake on Lan option. With WOL enabled PC can be turned on by sending a special packet to its ethernet port. What you're talking about is BIOS setting which tells PC what to do when power "returns".
In both cases RouterOS has got nothing to do with it.
mushmx
Thu Mar 12, 2009 5:35 am
Yeah, I'm agree with you but in this case the motherboard don't have the "automaticaly on power", so I think that will add the WOL into RouterOS could be a plus, cuz the mostly motherboard have the option WOL into BIOS.
Best regard :D
mushmx
Thu Mar 12, 2009 6:04 am
ok, I going to try to explain me much better, I know that the mostly motherboard have the WOL option and this can turn on the PC by sending special packet OK and some motherboard have the option that turn on automatically when the power return.
My point is that my PC only have the WOL option "enable" and in the same network I have MKT 511. When the power return the 511 automatically turn on but the PC not. So with the WOL option into RouterOS could setting some rule to checking if the PC is online and if not then send the magic packet WOL to turn on.
This is my opinion :D Maybe I'm wrong but at least for me this will help me, specially in rural sites. :D
JJCinAZ
Thu Mar 12, 2009 7:45 am
You could setup an EoIP tunnel and then use a remote PC or Linux to send a WOL Magic packet.
mushmx
Wed Apr 22, 2009 4:53 pm
Hi
I'm reading that Mikrotik finally has decided include the Wake On Lan into RouterOS.
Thanks Mikrotik Team :D
Best regard.
xezen
Long time Member
Long time Member
Thu Apr 23, 2009 11:57 am
well so far its talk as i have loaded 3.23 os but the options arntthere but now we know if we wait somtime things do change and im glad that mikrotik has added the wol option to the router os thanks mikrotik
normis
Thu Apr 23, 2009 12:06 pm
it will be in v3.24 :)
xezen
Long time Member
Long time Member
Thu Apr 23, 2009 11:02 pm
any idea on when that willbe or willittake some time?
Users browsing this forum: No registered users and 103 guests
