titius
OSPF redistribute-connected
Tue Jun 03, 2008 9:52 pm
What does mean redistribute-connected option in ospf .
When I set up ospf with or without redistribute-static everything is working, so I cant see difference . . .
ashish
Long time Member
Long time Member
Re: OSPF redistribute-connected
Wed Jun 04, 2008 6:15 am
you will get three Options in "redistribute-static"
1. as-type-1
2. as-type-2
3. no
The Default value is NO.
if you set the value, the router will redistribute the information about all static route which is available and manually added in routing database.
Example if "redistribute-static=as-type-1", Te router will redistribute the information about all static route of matric 1.
The static route means, a route which is manually added using "ip route add" command.
- AP - ASHISH PATEL - 757 309 0236 -
ste
Wed Jun 04, 2008 8:02 am
1. as-type-1
2. as-type-2
3. no
And connected are the routes where there is an ip configured.
Stefan
titius
Wed Jun 04, 2008 1:18 pm
Yes after turning on the braind I fogured it with your help :) . . .
thx
ludvik
Fri Jun 06, 2008 1:02 am
But: if ethernet interface does not link detect (pc or switch unplug), ospf NO REDISTRIBUTE any network assigned on this interface.
Is a bug or feature? IMHO bug ...
On wireless interfaces exists property disable-running-check, which is a solution this problem. But on ethernet ... nothing!(?)
p.s.: sorry my english
jirkaehm
Thu Apr 16, 2009 12:28 am
I'm having some troubles with redistributing connected routes into a different area.
I have backbone area where this function work's correcly.
Then I have approx 20 router's in area2 randomly conected between them.
I want to redistribute connected routes into OSPF.
When I set them to As type 1, routes are in OSPF routes but without area. Also on next router in network's routes are'nt displayed.
I solved this by adding each directed IP address into networks and set interface to passive mode. But more clear solution would be to get working redistribute connected routes.
Does anyone have some ideas?
thank you!
jirkaehm
Fri Apr 17, 2009 4:00 pm
Anyone with idea how to solve this? thx
Users browsing this forum: jerryroy1 and 36 guests
