MUM Europe 2020
trottolino1970
It's good to block ping........
Tue Jun 17, 2008 1:43 pm
It's good to block ping from the internet to my customer?
balimore
Forum Veteran
Forum Veteran
Re: It's good to block ping........
Tue Jun 17, 2008 1:54 pm
Hai fren,
no, and better when it traffic will put difference traffic on the networks.
i love investigation with ping command simple for. :wink:
regards
Hasbullah.com
trottolino1970
Tue Jun 17, 2008 1:58 pm
Hai fren,
regards
Hasbullah.com
yes ok but if i block ping isn't a new security for my customers to prevent attack?
hilton
Long time Member
Long time Member
Tue Jun 17, 2008 4:41 pm
You should only block certain (type/code) ICMP packets, not unilaterally.
So accept 0:0 and 8:0 (both Ping) and 11:0 and 3:3 (both traceroute) and 3:4 (Path MTU Discovery) and then drop the rest.
Regards
Hilton
trottolino1970
Tue Jun 17, 2008 4:45 pm
can you help me writing a good rule?
hilton
Long time Member
Long time Member
Tue Jun 17, 2008 5:01 pm
This should done in a jump rule but here goes nevertheless;
/ip firewall filter add chain=forward protocol=icmp icmp-options=0:0 action=accept comment="Allow Ping"
/ip firewall filter add chain=forward protocol=icmp icmp-options=8:0 action=accept comment="Allow Ping"
/ip firewall filter add chain=forward protocol=icmp icmp-options=11:0 action=accept comment="Allow Traceroute"
/ip firewall filter add chain=forward protocol=icmp icmp-options=3:3 action=accept comment="Allow Traceroute"
/ip firewall filter add chain=forward protocol=icmp icmp-options=3:4 action=accept comment="Allow Path MTU Discovery"
/ip firewall filter add chain=forward protocol=icmp action=drop comment="Drop all other ICMP"
This will allow your users/customers to use these utilities but you'll probably want to do something similar with the input chain, although this depends on whether you ping and tracert from the router itself.
Perhaps a rate limiting ping like this;
/ip firewall filter add chain=input action=accept protocol=icmp limit=50/5s,2
Hope this helps.
Regards
Hilton
trottolino1970
Tue Jun 17, 2008 5:03 pm
Hope this helps.
ok i try it and then explain eventually problem
thankyou
trottolino1970
Tue Jun 17, 2008 5:31 pm
ok i write it but all is ok execept the last that dont produce traffic. It's normal?
hilton
Long time Member
Long time Member
Tue Jun 17, 2008 5:33 pm
that will produce traffic when someone tries any of the other ICMP codes.
try this, disable the two ping rules and try and ping an external address (from a workstation).
Regards
Hilton
moazdabsheh
Sun Apr 06, 2014 9:54 pm
what about blocking only the trace ?? is it possible ?
francisuk24
Mon Apr 07, 2014 4:26 am
Depends, If they have Gaming certin games need to ping like battlefield and CSS etc
RouterBoard RB750R2, RouterOS Level 4
ISP: Zen Internet via VDSL 2 > 74.68Mb Down / 17.84Mb Up
docmarius
Mon Apr 07, 2014 8:07 am
Blocking ping is not security, just obscurity.
There are various other means to explore the network.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
onnoossendrijver
Mon Apr 07, 2014 1:17 pm
Most ping/ICMP traffic is way too useful (for troubleshooting ) to block in my opinion.
Blocking it is definitely not a security measure.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
moazdabsheh
Mon Apr 07, 2014 4:11 pm
what about blocking trace route ??
docmarius
Mon Apr 07, 2014 10:36 pm
You could pass all needed traffic and block the rest via sound firewall rules.
In that case, traceroute will be of no use for hacking.
But you can block it, of course.
Just that YOU won't be able to use it either.
Speaking of customers: If you provide them with real IP addresses, then a customer would expect to have full access to/from his IP, including traceroute and ping from the outside. If the customer wants, he still can block ping/traceroute at his endpoint.
If those addresses are NAT-ed, then it doesn't matter since you can not trace anything from the outside past the router. But from the inside, one still expects traceroute to work.
The only thing worth blocking is port 25 (SMTP) in both directions and offering a local SMTP server for mail sending, thus preventing unwanted direct spamming by malicious software. Of course with an option to opt-out of the blocking, if one needs to run his own mail server.
Users browsing this forum: No registered users and 44 guests
