Pepo
POE is it nessecary ???
Wed Jun 25, 2008 10:48 pm
Hi all,
I want to buy a router board from the markets and here in my country the seller asks me if i want a POE adapter, or normal adapter ???
I want to give him the best answer, also can i not buy the poe ???
:lol:
If you want please write to me the most important things i want to have AP wireless main ???
Equis
Forum Veteran
Forum Veteran
Re: POE is it nessecary ???
Thu Jun 26, 2008 3:29 am
Is your AP goint to be outside, get POE
inside in a arck, get normal
k.gen04
Sat Jun 28, 2008 2:24 am
I believe most routerboards have POE. If you do not need it now(mounted inside near a power point) you can always buy the adapter later(for mounting outside or in a roof, etc). My Mikrotik is mounted in the roof and runs POE from an adapter.
SweetSunday
Mon Jun 30, 2008 3:17 am
While I use PoE in certain situations I prefer to avoid it.
I will use it where the cable-run is 'out of harm's way' - that is, it's not likely to be interfered with, usually the subscriber's premises - as it's undeniably easier than having a second cable to the jack-plug. But where it's vulnerable, particularly in shared AP sites or where third-party or unauthorised intruders might deliberately or accidentally pinch, cut, drop-something on or yank the ethernet cable (to see what it's attached to?) I think the risk of the internal wires being damaged and shorting, possibly sending 48v up one of the data-lines, is too great.
But I'd be interested in what other's think.
Users browsing this forum: No registered users and 38 guests
