MUM Europe 2020
Pepo
Periodical Auto Reset
Sun Aug 31, 2008 3:48 am
Hi all,
I want to ask you about a script that do Periodical Auto reset to my whole server and let the server begin again to work but after i load my backup to it.
i want this period is 3 days later.
:lol:
Pepo
Re: Periodical Auto Reset
Mon Sep 01, 2008 12:56 am
Hey, no reply yet !!!
OK, I'm also want to disable some interfaces periodically...
normis
Mon Sep 01, 2008 10:19 am
why? this doesn't sound like a serous router setup. router must work without interruption all the time.
Pepo
Tue Sep 02, 2008 4:47 am
thanks for your answer normis,
but i want this information for education samples, i go to studying MT lessons as you told me on my last question, You remember ??!!!!
so i can show you what i'm do:
system schedule add /system reset
but i don't know how can i say yes
:o
sergejs
Tue Sep 02, 2008 9:01 am
At least requested scenario works for system reboot, you add 'system reboot' to scheduler, router won't wait for [y], it will automatically reboot the router.
I'm not sure about reset, but it could be reset is working in the same way, when it's added to script there is no [y] required, but reset router isn't good idea.
Perhaps it's much better to load specific backup file after time ?!
Pepo
Tue Sep 02, 2008 8:56 pm
thanks for all,
but i want also to disable a specific interface, can you tell me ???
:lol:
Users browsing this forum: Google [Bot] and 34 guests
