erudite
I WANT TO SETUP FRESH MIKROTIK SERVER
Sun Sep 21, 2008 11:44 pm
As a mikrotik beginner i want to start by been able to setup a small mikrotik server for 10pc.
The intend mikrotik server will serve as:
1. DHCP server.
2. Bandwidth Manager
3. Packet filltering, Port and web blocking.
4. Create Rules that are very essential for smooth and problem free network.
5.Hotspot configuration
Pls dont refer me to the manuals. i have tried to read and read I jst discover i need some one to help me on how-to-do practical and step by step command. I will be operation on VSAT. You can help me by assuming a WAN ip Address for me and also LAN. your responses and reply will highly appreciate.
thanks
janisk
Re: I WANT TO SETUP FRESH MIKROTIK SERVER
Mon Sep 22, 2008 12:14 pm
basically using manual you can configure routeros to you needs,
if you want someone to configure routeros for you, then you can caontact one of ppl in this list:
http://www.mikrotik.com/consultants.html
it wont be free of charge.
gmsmstr
Trainer
Trainer
Mon Sep 22, 2008 7:49 pm
I'm sure any of the MT Consultants on the list will be glad to help you. I would simpy get a public IP on your box, and then configure it up. Should take less than a hour of time! You can see the list at http://www.mikrotik.com/consultants.html
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
cyph3r
Tue Sep 23, 2008 1:16 pm
1. DHCP server.
thanks
Check this Bro.
http://wiki.mikrotik.com/wiki/Hotspot_server_setup
Regards,
Mehmood Ahmed |ĉУρĤ3г|
(+92)345-2835810
www.adminsline.com
adminsline.wordpress.com
E-mail: admin [at] adminsline.com
Egate
Long time Member
Long time Member
Tue Sep 23, 2008 2:18 pm
We dont mind helping people. But not spoonfeed, that said. If you run the hotspot wizard, it will se up all of these settings for you, only manual tweak, would be the bandwidth settings, which can be accomplish with hotspot or making us of simple queues, which i also realy straight forward.
Happy days. :-)
Users browsing this forum: No registered users and 48 guests
