MUM Europe 2020
Pepo
Metal or Wood Boxes ???
Mon Nov 03, 2008 5:51 pm
Hi all,
I now will purchase a new XR2 and mini routerboard system for my new wireless network and i want to ask what is the suitable box that i put my devices on it can i use the wood one or the metal one for outdoor AP ???
8)
rarbolay
Re: Metal or Food Boxes ???
Mon Nov 03, 2008 10:20 pm
InoX
Tue Nov 04, 2008 12:49 am
or use a plastic bag...if only they read on the producer site...
Pepo
Tue Nov 04, 2008 1:27 am
thanks for all,
but i still not having any answer for my important questions, i want to know the metal or wood box ??? i want to protect my wireless network from interference and atennuations caused by other wifi networks...\ :o
rarbolay
Re: Metal or Wood Boxes ???
Tue Nov 04, 2008 6:10 pm
attempting to attenuate RF interferance on a device that by design has an outdoor antenna is a bit impossible. The purpose of the enclosure is to protect from the environment and disipate heat. Wood or metal? Metal. Metal will disipate the heat created by the card better than wood and will actually stay weatherproof much longer. Dont bother building your own. The time / effort / materials to design and build your own boxes are more than the cost of pre-enginnered boxes.
roc-noc.com
Forum Veteran
Forum Veteran
Sun Jan 04, 2009 8:32 pm
thanks for all,
Radio waves travel through wood just fine. Metal stops them. Why would you even consider wood unless you are lining it with metal?
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
Users browsing this forum: Bing [Bot], CZFan and 36 guests
