mudasir
Error sending e-mail: invalid TO address
Wed Dec 03, 2008 8:19 am
I am trying to send my Backup file using "/tool e-mail" options, but it is giving me error.
Error is
"Error sending e-mail: invalid TO address"
I am using following command
/tool e-mail send to="cool_mudasir@hotmail.com" subject"Testing Mail" body="This is
a Test Mail From Mikrotik ROS" server[:resolve my.smtp.com] from="coolmudasir@gmail.com" file="CrystalNet.backup"
I dont know why this error is coming...can anyone please help me out in this...
The smtp server is provided by my ISP, which works fine, just not working with MK.
Regards
Mudasir Mirza
http://www.diglinux.com
bellis
Re: Error sending e-mail: invalid TO address
Thu Dec 04, 2008 7:49 pm
it looks like it may be an issue with authentication to the smtp server. to my knowledge, MT OS (as well as dude and other software that MT writes) does not have the ability to use mailservers that have authentication. for our dude, we had to create a mail server without authentication and then locked it down to the private ip of the dude machine. Havent found any other way around it.
"If it ain't broke, you're not tryin"
mudasir
Fri Dec 05, 2008 10:11 am
Dear i am using this SMTP server on other machine, and it does not require any authentication. So there must be something else worng wtih MT.
Regards
Mudasir Mirza
normis
Fri Dec 05, 2008 10:13 am
try other kinds of email addresses
balimore
Forum Veteran
Forum Veteran
Fri Dec 05, 2008 4:18 pm
Hello fren,
yup we are remember will give you simple idea...... Backup and SMTP update......
yes, ofcourse your execute is failed, try to SET first server name for.
i had success since 18 months ago with this http://forum.mikrotik.com/viewtopic.php?f=9&t=17102 until now and we have schedule every 12 hours will send of our backup scripts and SMTP updates Cetralized AAA. and everytime we received and monitor for IP address randomly from main ISP.
good luck....:wink:
again Thanks to Mikrotik & Teams
Hasbullah.com
Error is
mudasir
Sat Dec 06, 2008 12:10 pm
Thanks for the reply. I dont understand that script completely.
Dear Normis, when you say try other kind of e-mail address, i have tried gmail.com, hotmail.com, yahoo.com, live.com. Same error on all e-mail address.
I only want a simple way to mail my backup file created on alternate days to my mail address which is cool_mudasir@hotmail.com.
Regards
Mudasir Mirza
andrisuwignyo
Thu Jun 10, 2010 5:58 am
Error is
Hi mudasir, i'm also get same problem with my x86 with ROS ver.4.9, i think it's some bug in this version. any idea gan??
andrisuwignyo
Thu Jun 10, 2010 5:53 pm
fiuh... finally i've get a solved of this problem.
the key is:
[wignyo@Felix-Net] > tool e-mail print
    server: 74.125.155.109:25
  username: "my.gmail.account@gmail.com"
  password: "my.gmail.password"
and taraaaa.. this successfully running email sending from my x86 box
plisken
Sat May 03, 2014 4:38 pm
Who knows IP-address from Hotmail smtp-server and ports? for tools-email
Yukado
Thu May 22, 2014 5:57 pm
I would like to know if the email tool work well.
I am trying to send a mail using the yahoo mail server and I cannot do it.
Has anybody gotten success using that tool?
Thanks for your answers.
plisken
Thu May 22, 2014 6:05 pm
The email tool works perfect, but you must now the IP-address from the mail server and the port.
I use a pop3 server and this works perfect.
http://www.wirelessinfo.be/index.php/mi ... ages/email
Look to my website, sorry but no englisch but look to the printscreens a made
gersonsmanet
Fri Aug 18, 2017 6:04 pm
I was able to solve the problem.
I activated the firewall log and realized that the mikrotik address was on a spam list.
I followed the instructions of the site that was listed ip and removed from the list.
After a few minutes everything worked perfectly.
Users browsing this forum: Bing [Bot] and 39 guests
