panonit
ubiquiti roter station and mikrotik
Tue Dec 16, 2008 2:05 pm
new ubuquiti router station is comatibile with mikrotik?????????? :shock:
normis
Re: ubiquiti roter station and mikrotik
Tue Dec 16, 2008 2:07 pm
if you want to install RouterOS software on the Ubiquity device - No, it's not possible.
If you want to connect the routerstation to the MikroTik device - yes, it's possible.
panonit
Tue Dec 16, 2008 5:00 pm
OK,thanks for information!
thavinci
Fri Jan 30, 2009 8:53 pm
Not supported now or ever?
http://www.thavinci.za.net
echo "Demo license expired!"
echo "Please reinstall the router."
echo
kill -WINCH 1
exit
dolphinik1
Sun Mar 15, 2009 7:30 pm
Very bad news. RouterStation has good price with specs similar as RB433AH.
rmichael
Forum Veteran
Forum Veteran
Sun Mar 15, 2009 9:07 pm
mikrotik rb comes with good router/firewall/bridge software which is not free. If you consider the cost of software mikrotik is not that expensive.
Do I think ubiquity designs good hardware-yes, but they are not in the same class as mikrotik - at list not yet.
jp
Long time Member
Long time Member
Mon Mar 23, 2009 11:01 pm
433ah comes with l5 license for $150.
ub rs =69, l5 license = 95. I can't do math, but that's more than $150.
Users browsing this forum: Bogdantpa and 34 guests
