jone8880
how to turning Vlan?
Sun Aug 09, 2009 1:39 pm
I cant get working vlan between l3 switch and mikrotik. For examle i've got tagget vlan id 100(ip 10.0.0.1/30) from switch, and i created vlan interface on the ethernet interface which connected to switch. vlan id 100 (ip 10.0.0.2/30). So i cant ping 10.0.0.1. What i do wrong?
bdr
Trainer
Trainer
Re: how to turning Vlan?
Sun Aug 09, 2009 2:06 pm
If you properly set trunk connection from switch to MT it should work. What switch is it?
bdr
jone8880
Sun Aug 09, 2009 8:19 pm
edge-core 4612
config is: vlan 100(10.0.0.1/24) from dlink 3526---> port9 (edge-core 4612( only vlan 1) port10-->mikrotik vlan 100 (10.0.0.2/24)
if i create vlan interface 100 with 10.0.0.3/24 on Egle-Core, i can ping 10.0.0.1 but cant ping 10.0.0.2.
Chupaka
Sun Aug 09, 2009 9:52 pm
you need to add vlan100 to 4612 with port9&10 tagged
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jone8880
Mon Aug 10, 2009 1:28 pm
find mistake... was checked "use service tag"
Users browsing this forum: jamrobe and 32 guests
