GuJack20
Trainer
Trainer
RB450 vs RB750
Wed Sep 09, 2009 10:06 pm
Hi guys.
I know this has been brought up before. But we just got our first bunch of RB750 and i have some questions.
Has anyone of you any data of real life experiences of RB750 vs a RB450 ?
I know all the different quality, rb750 has a switch chip, it doesn't have a serial port,RB450 has level 5 etc, reasons but i would like to know if there is a real felt difference of pps passing on each one?
Many thanks and excuse me for being lazy and not testing everything myself, but this time i'm a little bit in a hurry.
--Do you remember that guy who gave up? Neither does anybody else!
normis
Re: RB450 vs RB750
Thu Sep 10, 2009 8:55 am
Everyone just got their first Rb750, they are only shipping for a few days, so you will not get any real life tests yet. I can tell you that the throughput is very good, and that the major differences you already found.
opampca
Re: RB450 vs RB750
Fri Sep 11, 2009 7:34 am
Well, do all rb450 come with level5 ?
I purchased one few weeks ago, and got level4...
Richard
normis
Re: RB450 vs RB750
Fri Sep 11, 2009 8:38 am
yes, your free Level5 can be obtained via the "upgrade key" button in winbox license menu. This is because not all resellers have the latest stock
GuJack20
Trainer
Trainer
Re: RB450 vs RB750
Fri Sep 11, 2009 8:41 am
You must install a version higher than 3.24 and than in the license section in winbox pres "update key".
Thanks Normis for the answer about the difference of the 2 rbs.
opampca
Re: RB450 vs RB750
Sat Sep 12, 2009 11:27 am
I have 3.22 installed, it says that it is upgradable to v4.x.
When I try to upgrade, it says "not enough prepaid keys...
Sorry for hijacking the thread..
meno
Re: RB450 vs RB750
Sun Sep 13, 2009 11:05 pm
the RB750 has a switch chip on it the rb450 doesnt, and also use another processor.... AR9240
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB450 vs RB750
Mon Sep 14, 2009 12:50 am
If the RB450 has no switch chip then how do you slave RB450 ports to another through hardware? (Because it works.)
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
opampca
Re: RB450 vs RB750
Thu Sep 17, 2009 7:52 am
Thank you.
RB450 upgraded fine to level5
dog
Re: RB450 vs RB750
Thu Sep 17, 2009 11:02 pm
I tried a RB750 on a VDSL50 line (Germany) with some NAT and firewall rules.
I could get 48 Mbits throughput and 50-70% CPU load with a few hundred Torrents...
Users browsing this forum: No registered users and 44 guests
