DanielRomero
install operating system mikrotik in a compact flash
Thu Sep 10, 2009 2:28 am
how to install operating system mikrotik in a compact flash
Thankyou
Daniel
roc-noc.com
Forum Veteran
Forum Veteran
Re: install operating system mikrotik in a compact flash
Thu Sep 10, 2009 5:50 am
Download the ISO image. Burn a CD. Boot from it.
Then install on a pre-formatted, flash drive.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
kurei
Thu Sep 10, 2009 6:34 am
If you want install form computer, I think you need converter IDE to CF. :arrow:
caxz
Sun Sep 13, 2009 2:30 am
Tom
hii... Tom..
how to install operating system mikrotik in a compact flash on RB/600?
thanks..
GuJack20
Trainer
Trainer
Sun Sep 13, 2009 6:07 pm
Why would you need that??
--Do you remember that guy who gave up? Neither does anybody else!
normis
Mon Sep 14, 2009 10:21 am
you can't boot RouterOS from the RouterBOARD CF slots
kurei
Thu Sep 17, 2009 5:31 am
umm..hi Normis.
May be it's not the right place to ask about it. But I'm sorry I've little question about RB450G.
I've new RB450G that already installed ROS 3.25 as default ROS and it can't be able to upgrade to level 5. The router already have 8 digit of soft-id and stay in level 4. Then I upgrade to ROS 3.28, when I click Update "license key" appeared information that told license key already update but the level of router still stay in level 4. :oops:
Is RB450G not in level 5 again?
normis
Thu Sep 17, 2009 9:36 am
you have to email support about it
caxz
Thu Sep 17, 2009 9:45 am
==from rb600ugA.pdf page 8==
boot device – initial boot device (boot over Ethernet | boot from NAND, if fail then Ethernet | boot from
CompactFlash only | boot Ethernet once, then NAND | boot Ethernet first, then CompactFlash | boot from
NAND only; boot from NAND, if fail then Ethernet by default). You can also select boot chosen device
option to boot from the device selected immediately, without saving the setting.
what OS can boot from C.F.???
normis
Thu Sep 17, 2009 10:07 am
other OS, not RouterOS
Users browsing this forum: No registered users and 34 guests
