zgi
RB750 beginner questions
Thu Oct 22, 2009 7:23 pm
HI!
I intend to buy RB750 for start, to get familiar on routerboards. And my first question is, if this model or. routerOS supports PPPoE server, or only PPPoE client.
I would like to do a small network, on wich every one connected on this network, will have to connect to internet using PPPoE protocol.
Thank You!
fewi
Re: RB750 beginner questions
Thu Oct 22, 2009 7:31 pm
It supports PPPoE servers.
RouterOS functionality is determined by license level. When you purchase an RB750, it comes with a specific license level, and you can upgrade it to higher license levels.
http://wiki.mikrotik.com/wiki/All_about_licenses
And here the differences between license levels: http://wiki.mikrotik.com/wiki/License_levels
normis
Fri Oct 23, 2009 9:49 am
correction, it supports both PPPoE server _and_ client. If you want a bigger server, you will need to buy a Level5 or 6 license for it additionally to the router's cost!
zgi
Fri Oct 23, 2009 2:21 pm
I think that, L4 with 200 possible PPPoE tunnels will be enough.
Thank you both, for replies
nwabuzik
Thu Dec 03, 2009 12:54 pm
Please Some help meI want to configure this
Moderm(ISP) to....RB750 to .....AP(WIRELESS)......
I want the RB750 TO DO BOTH USER MANAGER AND HOTSPOT
my ISP IP ADD IS ......
62.56.159.186
255.255.255.248
62.56.159.185
81.199.3.4
81.199.3.18
PLEASE SOMEONE HELP ME THANKS
Red0ktober
Mon Dec 07, 2009 10:20 pm
Similar to what I did. I'm not working 100% yet, but getting there. Though I'm posting this over PPPoE on my bench test RB450G pppoe server, authenticating to a RB1000U w/ user manager.
Log in with serial and run the setup, that is the easy way to get your IP in there. Then log in with winbox and add the ppp and user manager packages.
If you're doing NAT, you'll have to set that up, I've never done it...
http://wiki.mikrotik.com/wiki/NAT_Tutorial
Then PPPoE and User Manager:
http://wiki.mikrotik.com/wiki/User_Manager/PPP_Example
Users browsing this forum: Ahrefs [Bot], cmmike, donmunyak, hatred, jamesperks and 41 guests
