speedzonenetwork
Installing USB Lan card in Mikrotik?
Wed Jan 27, 2010 4:57 pm
I need to install 1 more interface on my Mikrotik RouterOS server.
But dont have an extra slot for new lan card.
thats y i purchased USB Lan card to fulfill my requirment. (USB 3.0 Full Speed Network Adapter)
now, the problem is, driver is not installing automatically and i dont have its driver for Mikrotik and dont know how to install its driver.
please guide with the procedure.
speedzonenetwork
Re: Installing USB Lan card in Mikrotik?
Wed Jan 27, 2010 11:36 pm
Any suggestion?
csickles
Wed Jan 27, 2010 11:58 pm
From an perev. post...
Hi, I saw video on tiktube about usb ethernet support. Is mikrotik supports only planet and linksys or it supports every ETH USB interface with same chipset as planet or linksys?
Is it possibile to implement USB wireless support ?
Look at the linksys..
Things that make you go "Hmmmmmmmm"...
Craig
speedzonenetwork
Thu Jan 28, 2010 12:05 am
why not Mikrotik installs other USB lan cards drivers?
i have davicom usb network adapter.
please guide me how to install Davicom Usb lan card on Mikrotik?
csickles
Fri Jan 29, 2010 3:08 am
Drivers CAN NOT be added to RouterOS by users..
The driver selection is a CLOSED system.
What is there is there. Only MikroTik can add or remove drivers.
Craig
normis
Fri Jan 29, 2010 10:52 am
We have some USB Dlink card added by someone here: http://wiki.mikrotik.com/wiki/Supported ... t_chipsets
csickles
Fri Jan 29, 2010 3:18 pm
Craig
speedzonenetwork
Mon Feb 08, 2010 11:54 am
Thanks csickles.
Linksys & Planet USB Network Adapter Are Available in Pakistan.
Please List All The Names Of Supported USB LAN Adapter on Mikrotik.
So that i will able to go for alternate.
speedzonenetwork
Mon Feb 08, 2010 11:53 pm
Please Write the list.
Thanks.
csickles
Tue Feb 09, 2010 12:04 am
I dont have the list...
I looked at the list on the WIKI..
I dont know any others that use the same chipset..
Craig
speedzonenetwork
Tue Feb 09, 2010 12:12 am
Did u test any USB Ethernet on Mikrotik?
speedzonenetwork
Tue Feb 09, 2010 5:32 pm
Please List The Supportable USB Ethernet Adapter So I Will Able Search For Alternate.
Linksys , Planet Ue-9500 & Dlink DUB-E100 Are Not Available In Pakistan.
Thats y asking for your expertise support.
Thanks.
fewi
Tue Feb 09, 2010 5:41 pm
You could have just figured out the chipset via google and then found lists like below that list devices that use them:
http://www.sustworks.com/site/news_usb_ethernet.html
speedzonenetwork
Tue Feb 09, 2010 5:56 pm
Thanks alot fewi.
you always guide me on right way.
all these models will work on Mikrotik?
Thanks Again.
fewi
Tue Feb 09, 2010 6:00 pm
I don't know. I don't use USB Ethernet adapters. But that page reports some devices to use the same chipset as the D-Link reported to be working (AX8817X). Drivers tend to be chipset specific.
khalil345
Sun Nov 13, 2016 6:52 pm
all dear i need some info about this lan card...
how too make lan card pc too convert usb pin any expert have method too hardware attechment info...
i have open A smart pc like cd room i need instal microtick hotspot application on it...
and use 1 other ethernet port...to LAN OR WAN...
Zwodka
Tue Nov 15, 2016 3:41 pm
I've tested these:
- ASIX AX88172 (D-Link DUB-E100 USB)
- ASIX AX88178 (Delock 61969)
- ASIX MosChip MCS 783x (Delock 61147)
These works fine :-)
marcelinghdz
Tue Jan 10, 2017 9:25 pm
I've tested these:
I have CCR-1009-8G-15-15+
I'm trying to connect to him D-link usb 2.0 Fast Ethernet Adapter DUB-E100 but it doesn't work for me.
Help!
Users browsing this forum: No registered users and 47 guests
