caspat
PPPOE ip Adress assignement
Wed Apr 28, 2010 4:00 pm
Hi all!
Ok i have configure a pppoe server using the wiki, when i connect to pppoe i get an adresse 10.0.0.1 ( from ip pool i have created) netmask 255.0.0.0 no default gateway... is this normal?
Thanks!
mrz
Re: PPPOE ip Adress assignement
Wed Apr 28, 2010 4:37 pm
netmask should be /32 not /8
caspat
Wed Apr 28, 2010 4:56 pm
I know but where do i change this?
mrz
Thu Apr 29, 2010 9:15 am
You don't change it. /32 is by design. If your client is not installing /32 route then there is a bug in pppoe client.
russman
Thu May 20, 2010 9:30 pm
I'm using 5.0Beta2 and I'm having trouble with my PPPOE clients as well. They are getting a /32 subnet and a 0.0.0.0 default gateway but they can't ping anything outside of the local subnet. Its as if they don't have a default gateway... Not sure what to do here. If I connect without PPPOE and just pickup an address from the default DHCP pool everything works correctly.
Users browsing this forum: No registered users and 34 guests
