Add wireless card to your router, set basic configuration,
/interface wireless set wlan1 mode=ap-bridge band=supported_band frequency=allowed_frequency_in_your_country ssid=SSID
Thanks sergejs for you help, but i am very beginner to routerOS. which wireless card i have to add in router ?
i am using senao long range multi client bridge as my AP. i just connected its ethernet port to my pc based routeros LAN's ethernet port. but it didn't work. i tired to add wireless interface through winbox, but it gave me error; "Could not change interface <wlan1> - cannot attach virtual AP to virtual AP (6)", when i enter SSID. what i am doing wrong here....
Wireless clients should find you wireless network by SSID.
Do not forget to add IP address to wireless interface, or you can add wireless interface to bridge with local Ethernet interface to share the same network between two interfaces.
how to bridge wireless interface with ethernet interface?
I able to connect internet when connected thru cable to my laptop from routerOS internal NIC. that is working fine, wonder if i am able to bridge wireless interface with this working internal NIC.
I was going to do the same thing... but what's the point to create WLAN interface for external AP that router can't configure anyways? From router's perspective it's just another Ethernet device
edmidor, same problem, router unable to find configuration of my AP. i have manually configure AP with static ip, gateway, dns. but router didnot recognize it.
Regards,
Vick
