MUM Europe 2020
neandero
Host removed: limiting address per mac !
Mon May 10, 2010 12:51 pm
All members who is using NanoStation to connect to my hotspot get removed every 5 - 10 minutes.
error: host removed limiting address per mac.
any other member who is not using NanoStation to connect is fine without any problem.
on hotspot user managment: Shared User:
i put 1 same problem
i put 2 same problem
i put 100 same problem...
sergejs
Re: Host removed: limiting address per mac !
Mon May 10, 2010 3:29 pm
There is no any relation to Nanostation and MAC-address problem, but most likely problem is caused by fact, that multiple users are connected to Ubnt router.
Shared user is limit, which is applied for authenticated users.
Default setting addresses-per-mac=2 is limited by,
/ip hotspot print
Perhaps you need to increase the default value to avoid the problem in the future.
babbage
Trainer
Trainer
Thu Apr 25, 2013 1:04 pm
How come MK hotspot knows client internal IP addresses which are behind the UBNT router? I replaced UBNT with RB of course NAT enabled but still the same. It's even the same by only having MAC authentication enabled. So there is not HTTP.
It just adds internal IP addresses with UBNT's wan mac address to the IP hotspot hosts.
Any idea?
soamz
Mon Aug 17, 2015 12:34 pm
I switched it off.
Any harm ?
Users browsing this forum: MSN [Bot] and 41 guests
