MUM Europe 2020
gcs
bandwidth settings with queue
Tue May 18, 2010 10:13 pm
I need to set user bandwidth I do it by setting it in a simple queue on the RB\433 we use as access points. I can set any speed up to 1 M but there is no setting higher other than 2 M. I would like to set to 1.5 M. Is there a way?
Not sure if I need to post a different message but I need to port forward/map tcp port 443 in the customers RB\133c. the Wan address is a real address and the Lan address is fake 10.10.10. can any one show me the code?
David Gower
Ibersystems
Re: bandwidth settings with queue
Wed May 19, 2010 11:37 am
to your first question, you could use "k" instead of "M" then... 1500k will be 1.5M.
for your 2nd question, read this in the wiki:
http://wiki.mikrotik.com/wiki/How_to_li ... Local_ones
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
gcs
Wed May 19, 2010 3:29 pm
Thanks the 1500K worked.
on the second I still need help on maping a port 443 to a 10.10.10.2 lan address
Ibersystems
Thu May 20, 2010 8:56 am
/ip firewall nat add action=dst-nat chain=dstnat comment="OPEN 443" disabled=no \
    dst-address=YOUR_ROUTER_IP_ADDRESS_CONECTED_TO_ADSL_ROUTER dst-port=443 in-interface=\
    YOUR_IN_INTERFACE protocol=tcp to-addresses=10.10.10.2 to-ports=\
    443
Remember that you have to open your 443 port in your ADSL router and redirect it to your Routerboard.
Martín
Users browsing this forum: No registered users and 55 guests
