Gilfre
Ethernet Interfaces show "R" running even with no cable on
Thu Aug 26, 2010 11:58 pm
Hi
Im wondering if someone has got the same thing.
I have installed the RouterOS 4.11 x86 in 2 diferent machines, a Portwell NAR-5020 and a Supermicro sever, and in both machines the ethernet interfaces show the "R" running even if I disconect the cables. I have to say that it seems to work fine as I plugged the cables and surffed Internet through the machines, but rare thing. Don´t you think???
Is that normal in this version???
Thank you to you all and keep working this good.
Greeetings
Gilfre
fewi
Re: Ethernet Interfaces show "R" running even with no cable
Fri Aug 27, 2010 12:02 am
http://wiki.mikrotik.com/wiki/Manual:In ... Properties
disable-running-check (yes | no; Default: yes) Disable running check. If this value is set to 'no', the router automatically detects whether the NIC is connected with a device in the network or not.
On x86 running-check defaults to "yes", so all interfaces are always considered running. Set it to 'no' if you want connectivity detection.
Gilfre
Fri Aug 27, 2010 2:35 pm
Heyyy
Thank you very much, as it is sometimes, silly things that we do not see, I will check today and let you know, but Im sure that is the detail.
I thought something was wrong, but wierd in two different machines made me kind of worry.
Thanks a lot once again
Gilfre
mrz
Fri Aug 27, 2010 2:41 pm
x86 by default has disabled running check. RouterBoards has enabled running check.
gmsmstr
Trainer
Trainer
Fri Aug 27, 2010 5:24 pm
What was the reason for changing this on x86? Just wondering.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
angboontiong
Sun Aug 29, 2010 4:47 am
If set to no, what the routerboard will do if the connection is fail?
i was thinking this possible can solve the ethernet halt issue or not.
helectro
Wed Oct 06, 2010 5:24 am
Hi where put No the options is
/interface ethernet>
.. : blink disable enable find monitor reset-counters set
/ mirror comment edit export get print reset-mac
fewi
Wed Oct 06, 2010 6:07 am
This is for x86 only, not for RouterBOARDs.
helectro
Thu Oct 07, 2010 2:30 am
Thank Fewi
yes i have many x86 but i dont Know where put this comand wrote
in terminal interface ether and no see where??
xxiii
Thu Oct 07, 2010 10:58 pm
Unfortunately, this particular option is in the form of a double-negative.
Users browsing this forum: No registered users and 19 guests
