Trimitsos
WEP & WPA in Mikrotik
Tue Sep 14, 2010 9:01 am
Does anybody know how and where do I enter the WEP key in Mikrotik menu,
in order to connect to a wireless modem, through one of my routerboard's wireless interfaces?
blake
Re: WEP & WPA in Mikrotik
Tue Sep 14, 2010 12:19 pm
hilton
Long time Member
Long time Member
Tue Sep 14, 2010 2:05 pm
I don't think Mikrotik supports WEP.
normis
Tue Sep 14, 2010 2:16 pm
the post above yours proves you wrong :)
hilton
Long time Member
Long time Member
Tue Sep 14, 2010 2:19 pm
Seriously?
I've just checked and I all I see is WPA and WPA2. Nuffin about WEP. I thought no-one used WEP anymore?
Surely?
normis
Tue Sep 14, 2010 2:26 pm
coffee?
hilton
Long time Member
Long time Member
Tue Sep 14, 2010 2:28 pm
coffee?
It would indeed appear so :-)
normis
Tue Sep 14, 2010 2:29 pm
But that doesn't mean anyone should use WEP.
Ibersystems
Tue Sep 14, 2010 4:02 pm
You can use WEP keys.. if you have the good idea of do it.. xD
With Mikrotik you could use 802.11b too.. instead of 802.11g.. I think it's normal.
Normis, give me the coffee : D!
Trimitsos
Fri Sep 17, 2010 10:18 am
I do use 802.11b mode in one of my wireless interfaces.
Since this is a BASIC RULE in order to connect to the wireless community called AWMN, as client!
Nevertheless I was wrong the Wi-Fi router uses wpa-psk
"blake" covered me after all, thank you for the help.
I will try this once I find some time at home.
(I will also check on wiki.mikrotik site, its great! and I am a newbi!)
Users browsing this forum: 9m2pju, jstaw, phascogale, voytecky and 35 guests
