kaptain1
Accessing WinBox remotely
Fri Oct 01, 2010 6:44 pm
Good morning,
I opened a port number 8291 on my RB450G to access WinBox remotely, and I have "Secure Mode" box checked in Win-Box as well as the "lock symbol" in top right corner, but I have a few security related concerns:
1. Is this an acceptable way of accessing Mikrotik from outside? (just by opening a port) Any concerns?
2. Is my username/password encrypted when I connect?
3. Is WinBox traffic encrypted? Is it strong encryption, or weak?
4. This "Secure Mode" is it really secure? Or just a bit better than "plain text"?
Do I need to worry about anything? And is there a better/safer way to access Mikrotik via WinBox remotely?
Thank You
usmans
Re: Accessing WinBox remotely
Fri Oct 01, 2010 11:00 pm
disable network discovery u will become more secure
sorry for bad english
fewi
Sat Oct 02, 2010 2:14 am
On Monday or Tuesday the slides from the 2010 US MUM will be posted here: http://wiki.mikrotik.com/wiki/MUM_2010_US
Steve Discher had a presentation on port knocking, and it's already up. You should take a look at it.
nirmal
Wed Jul 31, 2013 8:54 am
where we can find the network discovery?
How to make IP access list? which means some of Particular Ip only it will be able to access like tht...
Zavi
Wed Jul 31, 2013 11:51 am
/ip neighbor discovery
and disable WAN port, this will stop RB from broadcasting, that it is on network.
If you need to set only one range or address, you can set it right in
/ip service edit winbox address
For more addresses or ranges use firewall and his address lists:
/ip firewall address-list
add list=winboxaccess address=192.168.2.0/24
add list=winboxaccess address=1.1.1.1
add list=winboxaccess address=2.2.2.2
/ip firewall filter add chain=input action=accept src-address-list=winboxaccess protocol=tcp dst-port=8291
Don't forget to move this rule above drop/reject rules!
You can do more advacned config such as port knocking with firewall and address lists too.
RB751G-2HnD & RB2011UiAS-2HnD-IN at home
nirmal
Tue Aug 06, 2013 7:19 am
/ip service edit winbox address - I hope the above comment is working I believe. we will able to control the access with only defind IP's here.
Small dought:
I dont thing so the firewall command will help for the secure access, kindly suggest us which one is good to control the mikrotik access control? My consecrate is it's should be able to access form all places, it should be able to access only from defined IP's?
for the above command , I have created the Management servers in the address-list, then I have written the rule in firewall & same time i made the accept for only Management server IP's & made drop for all but it didn't help to block the access. here with i attached config sheets . kindly help me, if this won't work what is the purpose to use this firewall comment.
Users browsing this forum: Bing [Bot] and 59 guests
