MUM Europe 2020
caspat
Reset TX and RX bytes
Tue Feb 08, 2011 9:05 pm
Hi all!
How can i reset the TX/RX bytes on interface?
Pat
blake
Re: Reset TX and RX bytes
Tue Feb 08, 2011 10:08 pm
From the CLI.
reset-counters <interface name>
IT consultant. Network manager. Packet junkie.
1-928-328-1509
caspat
Tue Feb 08, 2011 10:26 pm
It does not work...
Feklar
Tue Feb 08, 2011 10:51 pm
interface ethernet reset-counters <interface name>
caspat
Wed Feb 09, 2011 3:21 am
that is what i did...
Pat
el berto
Fri May 27, 2011 11:59 am
Hi, I've seen on Winbox:
Interface list -> Interface <ether1> window -> Traffic
or
Wireless tables -> Interface <wds1> window -> Traffic
there is "Tx/Rx Bytes" counter.
two questions:
1) how can I see it through telnet?
2) how can I reset these counters? with command line above there are no changes on interface window.....
Hotz1
Mon May 02, 2016 2:34 am
Has anyone found an answer for this? I'd like to use these counters to track data usage per subscriber (VLAN), and reset them to zero at the start of every month. I can't figure out how to reset them, short of rebooting the router.
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
pe1chl
Tue May 03, 2016 2:25 pm
That would not be reliable anyway, as your counters would get reset at a reboot.
What you need to do is:
- read the counters from another system with SNMP
- keep a "last read value"
- handle the case where there is a very big jump between two reads, assume the router has been rebooted
- this way, keep a valid usage figure over the past read interval and store it in some database
- generate your usage figures from that
This is a mechanism that is present in some SNMP monitoring packages.
tgs
Thu Jul 27, 2017 5:00 pm
I need to reset interface vlan counters every month too.
Has anyone make this?
Best
Users browsing this forum: abrar226, fedus, mbovenka, mojbuk and 31 guests
