kordeul
750g PPPoE to LAN
Fri Feb 25, 2011 5:35 pm
Hi
I'm trying to setup home network. I'm using 750g as the router for xDSL. I have setup PPPoE on 750g. This is working and I can see the connection is established. What I can't do is get this connection available for computers on the LAN, connected to 750g. I was reading various posts on this forum and some suggest to create bridge, some to create nat masquerade. I've tried all but no luck...
Can someone give me more specific instructions? I'm completely new to this level of networking so detailed instructions are welcome :)
fewi
Re: 750g PPPoE to LAN
Fri Feb 25, 2011 8:42 pm
Post the output of "/ip address print detail", "/ip route print detail", "/interface print", and "/ip firewall export"
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
kordeul
Fri Feb 25, 2011 8:50 pm
Ok, here it is:
[admin@MikroTik] > /ip address print detail
 0   ;;; default configuration
     address=192.168.88.1/24 network=192.168.88.0 broadcast=192.168.88.255 interface=bridge1
     actual-interface=bridge1
[admin@MikroTik] > /ip route print detail
 0 ADC  dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge1
        gateway-status=bridge1 reachable distance=0 scope=10
[admin@MikroTik] > /interface print
 #     NAME                                                            TYPE             MTU   L2MTU
 0     ether1-gateway                                                  ether            1500  1524
 1  R  ether2-local-master                                             ether            1500  1524
 2     ether3-local-slave                                              ether            1500  1524
 3     ether4-local-slave                                              ether            1500  1524
 4  R  ether5-local-slave                                              ether            1500  1524
 5  R  bridge1                                                         bridge           1500  1524
 6     pppoe-siol                                                      pppoe-out
[admin@MikroTik] > /ip firewall export
# jan/02/1970 01:02:36 by RouterOS 4.11
# software id = WY86-EVIY
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established \
    disabled=no in-interface=ether1-gateway
add action=accept chain=input comment="default configuration" connection-state=related disabled=\
add action=drop chain=input comment="default configuration" disabled=no in-interface=\
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=\
    pppoe-siol
add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe-siol
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Regards, Tom
fewi
Fri Feb 25, 2011 10:14 pm
Why are you bridging stuff?
kordeul
Fri Feb 25, 2011 10:22 pm
I have been trying all sorts of things - I read in this forum in several topics that I need to bridge, so I tried that. I also tried changing NAT rules, but didn't work it out. For each thing I reset router to factory settings (reset-configuration command) and started from there. My output reflects the last stuff I tried. If bridge is not needed, than I'm happy to reset once again and do it properly - but need directions as to what to do and how :)
Thanks, Tom
fewi
Fri Feb 25, 2011 10:58 pm
I see.
Reset to factory defaults, then connect via Winbox by MAC address (important! You're going to remove IP addresses further down, so you MUST connect via MAC address). The below is all text format configuration, so click the Terminal button and copy/paste the commands in.
Then run this to clean up the default interface configuration:
/ip address remove [/ip address find]
/ip dhcp-client remove [/ip dhcp-client remove]
Then add your PPPoE client to ether1-gateway, this interface then plugs into your modem. Replace your username and password for the service:
/interface pppoe-client
add interface=ether1-gateway user=user password=passwd disabled=no add-default-route=yes use-peer-dns=yes name=pppoe-ether1
Then configure an IP address for your LAN, make the DNS caching resolver available, and configure a DHCP server for the LAN. This assumes a LAN of 192.168.0.0/24. Replace all references as required if you need different IP addressing:
add address=192.168.0.1/24 interface=ether2-local-master
set allow-remote-requests=yes
add name=DHCP-Pool ranges=192.168.0.100-192.168.0.254 disabled=no
add address=192.168.0.0/24 gateway=192.168.0.1 dns-server=192.168.0.1 disabled=no
add authoritative=yes disabled=no interface=ether2-local-master lease-time=1d address-pool=DHCP=Pool
And then finally configure NAT for the LAN network out the PPPoE interface:
add chain=src-nat out-interface=pppoe-ether1 action=masquerade
Some firewalling is probably a good idea:
add chain=input connection-state=established action=accept
add chain=input connection-state=related action=accept
add chain=input connection-state=invalid action=drop
add chain=input in-interface=ether2-local-master action=accept
add chain=input action=drop
add chain=forward connection-state=established action=accept
add chain=forward connection-state=related action=accept
add chain=forward connection-state=invalid action=drop
add chain=forward in-interface=ether2-local-master action=accept
add chain=forward action=drop
That should do it. If you need to forward ports for services available from the WAN, here an example of forwarding port tcp/80 to an inside machine at 192.168.0.10:
add chain=dst-nat in-interface=pppoe-ether1 protocol=tcp dst-port=80 action=dstnat to-address=192.168.0.10
Then you also need to make a firewall rule permitting that traffic:
add chain=forward protocol=tcp dst-port=80 dst-address=192.168.0.10 action=accept
And then move that rule above the default drop rule in the forward chain.
Hope that helps.
forne
Sat Feb 26, 2011 4:22 am
Can you explain why do you use the rule
before the rule
? I think it's redundant.
fewi
Sat Feb 26, 2011 4:36 am
It stops invalid packets from entering the router (or traversing the router in the forward chain) even if they're sourced from behind the ether2-master-local interface.
kordeul
Sat Feb 26, 2011 10:33 am
Thanks a lot, this made it! I can now get internet on my LAN!
Thanks again!
Users browsing this forum: 0pl0pl, Google [Bot], xvo and 36 guests
