MUM Europe 2020
shadowskippie
NV2
Thu Mar 03, 2011 9:23 pm
just need a little help with understanding something
I read up that NV2 is is a time based system.
How does this effect something like skype that is tossing out packings and cannot afford to wait
CyberT
Re: NV2
Thu Mar 03, 2011 11:20 pm
nv2 does support QOS in its own way,
TDMA period size deals with that, as i understand that it will not exceed the tdma period size, cell radius also deals with that, as NV2 will reserve an addition time slot for "further" clients.
NV2 is aimed at P2MP environments but i have had great results on P2P connection.
The main difference with NV2 is that it does not adhere to waiting for a free time slot, but it pre-assigns time slots for devices, therefore it does not do a RTS CTS as with 802.11 that listens for the medium to be free, as with any wireless protocol a Clear Frequency is the key.
If this helped you then please slam that Karma button :-)
shadowskippie
Re: NV2
Fri Mar 04, 2011 7:36 am
okay
i'm interested setting our system to nv2 so this info helps
As for QOS skype, i'm not sure how to go about that. the QOS stuff i've read either requires me to know the destination IP (which with skype at any one time can be any IP) or know how it tells itself it is a voip packet (i think that was something to do with a TOL or TLO?), either way i look at it i'm not sure how to QOS this stuff
anyways, thanks for the help
savagedavid
Trainer
Trainer
Re: NV2
Fri Mar 04, 2011 8:09 am
AFAIK there is currently no 100% effective way to detect all Skype packets for effective QOS. There are some limited success L7 filters, but it seems every new Skype version changes the way it uses the network so it will probably only be 40-50% effective.
The filter below definitely captures packets but I cant tell you how effective it is. It will give you the necessary connection and flow marks which you can then use for QOS. If you try it let me know how well it works please.
/ip firewall layer7-protocol
:if ([:len [find name=skypeout]] > 0) do={ :put "already have skypeout" } else={ add name=skypeout regexp="^(\01.\?.\?.\?.\?.\?.\?.\?.\?\01|\02.\?.\?.\?.\?.\?.\?.\?.\?\02|\03.\?.\?.\?.\?.\?.\?.\?.\?\03|\04.\?.\?.\?.\?.\?.\?.\?.\?\04|\05.\?.\?.\?.\?.\?.\?.\?.\?\05|\06.\?.\?.\?.\?.\?.\?.\?.\?\06|\07.\?.\?.\?.\?.\?.\?.\?.\?\07|\08.\?.\?.\?.\?.\?.\?.\?.\?\08|\09.\?.\?.\?.\?.\?.\?.\?.\?\09|\0A.\?.\?.\?.\?.\?.\?.\?.\?\0A|\0B.\?.\?.\?.\?.\?.\?.\?.\?\0B|\0C.\?.\?.\?.\?.\?.\?.\?.\?\0C|\0D.\?.\?.\?.\?.\?.\?.\?.\?\0D|\0E.\?.\?.\?.\?.\?.\?.\?.\?\0E|\0F.\?.\?.\?.\?.\?.\?.\?.\?\0F|\10.\?.\?.\?.\?.\?.\?.\?.\?\10|\11.\?.\?.\?.\?.\?.\?.\?.\?\11|\12.\?.\?.\?.\?.\?.\?.\?.\?\12|\13.\?.\?.\?.\?.\?.\?.\?.\?\13|\14.\?.\?.\?.\?.\?.\?.\?.\?\14|\15.\?.\?.\?.\?.\?.\?.\?.\?\15|\16.\?.\?.\?.\?.\?.\?.\?.\?\16|\17.\?.\?.\?.\?.\?.\?.\?.\?\17|\18.\?.\?.\?.\?.\?.\?.\?.\?\18|\19.\?.\?.\?.\?.\?.\?.\?.\?\19|\1A.\?.\?.\?.\?.\?.\?.\?.\?\1A|\1B.\?.\?.\?.\?.\?.\?.\?.\?\1B|\1C.\?.\?.\?.\?.\?.\?.\?.\?\1C|\1D.\?.\?.\?.\?.\?.\?.\?.\?\1D|\1E.\?.\?.\?.\?.\?.\?.\?.\?\1E|\1F.\?.\?.\?.\?.\?.\?.\?.\?\1F|\20.\?.\?.\?.\?.\?.\?.\?.\?\20|\21.\?.\?.\?.\?.\?.\?.\?.\?\21|\22.\?.\?.\?.\?.\?.\?.\?.\?\22|\23.\?.\?.\?.\?.\?.\?.\?.\?\23|\\\$.\?.\?.\?.\?.\?.\?.\?.\?\\\$|\25.\?.\?.\?.\?.\?.\?.\?.\?\25|\26.\?.\?.\?.\?.\?.\?.\?.\?\26|\27.\?.\?.\?.\?.\?.\?.\?.\?\27|\\(.\?.\?.\?.\?.\?.\?.\?.\?\\(|\\).\?.\?.\?.\?.\?.\?.\?.\?\\)|\\*.\?.\?.\?.\?.\?.\?.\?.\?\\*|\\+.\?.\?.\?.\?.\?.\?.\?.\?\\+|\2C.\?.\?.\?.\?.\?.\?.\?.\?\2C|\2D.\?.\?.\?.\?.\?.\?.\?.\?\2D|\\..\?.\?.\?.\?.\?.\?.\?.\?\\.|\2F.\?.\?.\?.\?.\?.\?.\?.\?\2F|\30.\?.\?.\?.\?.\?.\?.\?.\?\30|\31.\?.\?.\?.\?.\?.\?.\?.\?\31|\32.\?.\?.\?.\?.\?.\?.\?.\?\32|\33.\?.\?.\?.\?.\?.\?.\?.\?\33|\34.\?.\?.\?.\?.\?.\?.\?.\?\34|\35.\?.\?.\?.\?.\?.\?.\?.\?\35|\36.\?.\?.\?.\?.\?.\?.\?.\?\36|\37.\?.\?.\?.\?.\?.\?.\?.\?\37|\38.\?.\?.\?.\?.\?.\?.\?.\?\38|\39.\?.\?.\?.\?.\?.\?.\?.\?\39|\3A.\?.\?.\?.\?.\?.\?.\?.\?\3A|\3B.\?.\?.\?.\?.\?.\?.\?.\?\3B|\3C.\?.\?.\?.\?.\?.\?.\?.\?\3C|\3D.\?.\?.\?.\?.\?.\?.\?.\?\3D|\3E.\?.\?.\?.\?.\?.\?.\?.\?\3E|\\\?.\?.\?.\?.\?.\?.\?.\?.\?\\\?|\40.\?.\?.\?.\?.\?.\?.\?.\?\40|\41.\?.\?.\?.\?.\?.\?.\?.\?\41|\42.\?.\?.\?.\?.\?.\?.\?.\?\42|\43.\?.\?.\?.\?.\?.\?.\?.\?\43|\44.\?.\?.\?.\?.\?.\?.\?.\?\44|\45.\?.\?.\?.\?.\?.\?.\?.\?\45|\46.\?.\?.\?.\?.\?.\?.\?.\?\46|\47.\?.\?.\?.\?.\?.\?.\?.\?\47|\48.\?.\?.\?.\?.\?.\?.\?.\?\48|\49.\?.\?.\?.\?.\?.\?.\?.\?\49|\4A.\?.\?.\?.\?.\?.\?.\?.\?\4A|\4B.\?.\?.\?.\?.\?.\?.\?.\?\4B|\4C.\?.\?.\?.\?.\?.\?.\?.\?\4C|\4D.\?.\?.\?.\?.\?.\?.\?.\?\4D|\4E.\?.\?.\?.\?.\?.\?.\?.\?\4E|\4F.\?.\?.\?.\?.\?.\?.\?.\?\4F|\50.\?.\?.\?.\?.\?.\?.\?.\?\50|\51.\?.\?.\?.\?.\?.\?.\?.\?\51|\52.\?.\?.\?.\?.\?.\?.\?.\?\52|\53.\?.\?.\?.\?.\?.\?.\?.\?\53|\54.\?.\?.\?.\?.\?.\?.\?.\?\54|\55.\?.\?.\?.\?.\?.\?.\?.\?\55|\56.\?.\?.\?.\?.\?.\?.\?.\?\56|\57.\?.\?.\?.\?.\?.\?.\?.\?\57|\58.\?.\?.\?.\?.\?.\?.\?.\?\58|\59.\?.\?.\?.\?.\?.\?.\?.\?\59|\5A.\?.\?.\?.\?.\?.\?.\?.\?\5A|\\[.\?.\?.\?.\?.\?.\?.\?.\?\\[|\\].\?.\?.\?.\?.\?.\?.\?.\?\\]|\\].\?.\?.\?.\?.\?.\?.\?.\?\\]|\\^.\?.\?.\?.\?.\?.\?.\?.\?\\^|\5F.\?.\?.\?.\?.\?.\?.\?.\?\5F|\60.\?.\?.\?.\?.\?.\?.\?.\?\60|\61.\?.\?.\?.\?.\?.\?.\?.\?\61|\62.\?.\?.\?.\?.\?.\?.\?.\?\62|\63.\?.\?.\?.\?.\?.\?.\?.\?\63|\64.\?.\?.\?.\?.\?.\?.\?.\?\64|\65.\?.\?.\?.\?.\?.\?.\?.\?\65|\66.\?.\?.\?.\?.\?.\?.\?.\?\66|\67.\?.\?.\?.\?.\?.\?.\?.\?\67|\68.\?.\?.\?.\?.\?.\?.\?.\?\68|\69.\?.\?.\?.\?.\?.\?.\?.\?\69|\6A.\?.\?.\?.\?.\?.\?.\?.\?\6A|\6B.\?.\?.\?.\?.\?.\?.\?.\?\6B|\6C.\?.\?.\?.\?.\?.\?.\?.\?\6C|\6D.\?.\?.\?.\?.\?.\?.\?.\?\6D|\6E.\?.\?.\?.\?.\?.\?.\?.\?\6E|\6F.\?.\?.\?.\?.\?.\?.\?.\?\6F|\70.\?.\?.\?.\?.\?.\?.\?.\?\70|\71.\?.\?.\?.\?.\?.\?.\?.\?\71|\72.\?.\?.\?.\?.\?.\?.\?.\?\72|\73.\?.\?.\?.\?.\?.\?.\?.\?\73|\74.\?.\?.\?.\?.\?.\?.\?.\?\74|\75.\?.\?.\?.\?.\?.\?.\?.\?\75|\76.\?.\?.\?.\?.\?.\?.\?.\?\76|\77.\?.\?.\?.\?.\?.\?.\?.\?\77|\78.\?.\?.\?.\?.\?.\?.\?.\?\78|\79.\?.\?.\?.\?.\?.\?.\?.\?\79|\7A.\?.\?.\?.\?.\?.\?.\?.\?\7A|\\{.\?.\?.\?.\?.\?.\?.\?.\?\\{|\\|.\?.\?.\?.\?.\?.\?.\?.\?\\||\\}.\?.\?.\?.\?.\?.\?.\?.\?\\}|\7E.\?.\?.\?.\?.\?.\?.\?.\?\7E|\7F.\?.\?.\?.\?.\?.\?.\?.\?\7F|\80.\?.\?.\?.\?.\?.\?.\?.\?\80|\81.\?.\?.\?.\?.\?.\?.\?.\?\81|\82.\?.\?.\?.\?.\?.\?.\?.\?\82|\83.\?.\?.\?.\?.\?.\?.\?.\?\83|\84.\?.\?.\?.\?.\?.\?.\?.\?\84|\85.\?.\?.\?.\?.\?.\?.\?.\?\85|\86.\?.\?.\?.\?.\?.\?.\?.\?\86|\87.\?.\?.\?.\?.\?.\?.\?.\?\87|\88.\?.\?.\?.\?.\?.\?.\?.\?\88|\89.\?.\?.\?.\?.\?.\?.\?.\?\89|\8A.\?.\?.\?.\?.\?.\?.\?.\?\8A|\8B.\?.\?.\?.\?.\?.\?.\?.\?\8B|\8C.\?.\?.\?.\?.\?.\?.\?.\?\8C|\8D.\?.\?.\?.\?.\?.\?.\?.\?\8D|\8E.\?.\?.\?.\?.\?.\?.\?.\?\8E|\8F.\?.\?.\?.\?.\?.\?.\?.\?\8F|\90.\?.\?.\?.\?.\?.\?.\?.\?\90|\91.\?.\?.\?.\?.\?.\?.\?.\?\91|\92.\?.\?.\?.\?.\?.\?.\?.\?\92|\93.\?.\?.\?.\?.\?.\?.\?.\?\93|\94.\?.\?.\?.\?.\?.\?.\?.\?\94|\95.\?.\?.\?.\?.\?.\?.\?.\?\95|\96.\?.\?.\?.\?.\?.\?.\?.\?\96|\97.\?.\?.\?.\?.\?.\?.\?.\?\97|\98.\?.\?.\?.\?.\?.\?.\?.\?\98|\99.\?.\?.\?.\?.\?.\?.\?.\?\99|\9A.\?.\?.\?.\?.\?.\?.\?.\?\9A|\9B.\?.\?.\?.\?.\?.\?.\?.\?\9B|\9C.\?.\?.\?.\?.\?.\?.\?.\?\9C|\9D.\?.\?.\?.\?.\?.\?.\?.\?\9D|\9E.\?.\?.\?.\?.\?.\?.\?.\?\9E|\9F.\?.\?.\?.\?.\?.\?.\?.\?\9F|\A0.\?.\?.\?.\?.\?.\?.\?.\?\A0|\A1.\?.\?.\?.\?.\?.\?.\?.\?\A1|\A2.\?.\?.\?.\?.\?.\?.\?.\?\A2|\A3.\?.\?.\?.\?.\?.\?.\?.\?\A3|\A4.\?.\?.\?.\?.\?.\?.\?.\?\A4|\A5.\?.\?.\?.\?.\?.\?.\?.\?\A5|\A6.\?.\?.\?.\?.\?.\?.\?.\?\A6|\A7.\?.\?.\?.\?.\?.\?.\?.\?\A7|\A8.\?.\?.\?.\?.\?.\?.\?.\?\A8|\A9.\?.\?.\?.\?.\?.\?.\?.\?\A9|\AA.\?.\?.\?.\?.\?.\?.\?.\?\AA|\AB.\?.\?.\?.\?.\?.\?.\?.\?\AB|\AC.\?.\?.\?.\?.\?.\?.\?.\?\AC|\AD.\?.\?.\?.\?.\?.\?.\?.\?\AD|\AE.\?.\?.\?.\?.\?.\?.\?.\?\AE|\AF.\?.\?.\?.\?.\?.\?.\?.\?\AF|\B0.\?.\?.\?.\?.\?.\?.\?.\?\B0|\B1.\?.\?.\?.\?.\?.\?.\?.\?\B1|\B2.\?.\?.\?.\?.\?.\?.\?.\?\B2|\B3.\?.\?.\?.\?.\?.\?.\?.\?\B3|\B4.\?.\?.\?.\?.\?.\?.\?.\?\B4|\B5.\?.\?.\?.\?.\?.\?.\?.\?\B5|\B6.\?.\?.\?.\?.\?.\?.\?.\?\B6|\B7.\?.\?.\?.\?.\?.\?.\?.\?\B7|\B8.\?.\?.\?.\?.\?.\?.\?.\?\B8|\B9.\?.\?.\?.\?.\?.\?.\?.\?\B9|\BA.\?.\?.\?.\?.\?.\?.\?.\?\BA|\BB.\?.\?.\?.\?.\?.\?.\?.\?\BB|\BC.\?.\?.\?.\?.\?.\?.\?.\?\BC|\BD.\?.\?.\?.\?.\?.\?.\?.\?\BD|\BE.\?.\?.\?.\?.\?.\?.\?.\?\BE|\BF.\?.\?.\?.\?.\?.\?.\?.\?\BF|\C0.\?.\?.\?.\?.\?.\?.\?.\?\C0|\C1.\?.\?.\?.\?.\?.\?.\?.\?\C1|\C2.\?.\?.\?.\?.\?.\?.\?.\?\C2|\C3.\?.\?.\?.\?.\?.\?.\?.\?\C3|\C4.\?.\?.\?.\?.\?.\?.\?.\?\C4|\C5.\?.\?.\?.\?.\?.\?.\?.\?\C5|\C6.\?.\?.\?.\?.\?.\?.\?.\?\C6|\C7.\?.\?.\?.\?.\?.\?.\?.\?\C7|\C8.\?.\?.\?.\?.\?.\?.\?.\?\C8|\C9.\?.\?.\?.\?.\?.\?.\?.\?\C9|\CA.\?.\?.\?.\?.\?.\?.\?.\?\CA|\CB.\?.\?.\?.\?.\?.\?.\?.\?\CB|\CC.\?.\?.\?.\?.\?.\?.\?.\?\CC|\CD.\?.\?.\?.\?.\?.\?.\?.\?\CD|\CE.\?.\?.\?.\?.\?.\?.\?.\?\CE|\CF.\?.\?.\?.\?.\?.\?.\?.\?\CF|\D0.\?.\?.\?.\?.\?.\?.\?.\?\D0|\D1.\?.\?.\?.\?.\?.\?.\?.\?\D1|\D2.\?.\?.\?.\?.\?.\?.\?.\?\D2|\D3.\?.\?.\?.\?.\?.\?.\?.\?\D3|\D4.\?.\?.\?.\?.\?.\?.\?.\?\D4|\D5.\?.\?.\?.\?.\?.\?.\?.\?\D5|\D6.\?.\?.\?.\?.\?.\?.\?.\?\D6|\D7.\?.\?.\?.\?.\?.\?.\?.\?\D7|\D8.\?.\?.\?.\?.\?.\?.\?.\?\D8|\D9.\?.\?.\?.\?.\?.\?.\?.\?\D9|\DA.\?.\?.\?.\?.\?.\?.\?.\?\DA|\DB.\?.\?.\?.\?.\?.\?.\?.\?\DB|\DC.\?.\?.\?.\?.\?.\?.\?.\?\DC|\DD.\?.\?.\?.\?.\?.\?.\?.\?\DD|\DE.\?.\?.\?.\?.\?.\?.\?.\?\DE|\DF.\?.\?.\?.\?.\?.\?.\?.\?\DF|\E0.\?.\?.\?.\?.\?.\?.\?.\?\E0|\E1.\?.\?.\?.\?.\?.\?.\?.\?\E1|\E2.\?.\?.\?.\?.\?.\?.\?.\?\E2|\E3.\?.\?.\?.\?.\?.\?.\?.\?\E3|\E4.\?.\?.\?.\?.\?.\?.\?.\?\E4|\E5.\?.\?.\?.\?.\?.\?.\?.\?\E5|\E6.\?.\?.\?.\?.\?.\?.\?.\?\E6|\E7.\?.\?.\?.\?.\?.\?.\?.\?\E7|\E8.\?.\?.\?.\?.\?.\?.\?.\?\E8|\E9.\?.\?.\?.\?.\?.\?.\?.\?\E9|\EA.\?.\?.\?.\?.\?.\?.\?.\?\EA|\EB.\?.\?.\?.\?.\?.\?.\?.\?\EB|\EC.\?.\?.\?.\?.\?.\?.\?.\?\EC|\ED.\?.\?.\?.\?.\?.\?.\?.\?\ED|\EE.\?.\?.\?.\?.\?.\?.\?.\?\EE|\EF.\?.\?.\?.\?.\?.\?.\?.\?\EF|\F0.\?.\?.\?.\?.\?.\?.\?.\?\F0|\F1.\?.\?.\?.\?.\?.\?.\?.\?\F1|\F2.\?.\?.\?.\?.\?.\?.\?.\?\F2|\F3.\?.\?.\?.\?.\?.\?.\?.\?\F3|\F4.\?.\?.\?.\?.\?.\?.\?.\?\F4|\F5.\?.\?.\?.\?.\?.\?.\?.\?\F5|\F6.\?.\?.\?.\?.\?.\?.\?.\?\F6|\F7.\?.\?.\?.\?.\?.\?.\?.\?\F7|\F8.\?.\?.\?.\?.\?.\?.\?.\?\F8|\F9.\?.\?.\?.\?.\?.\?.\?.\?\F9|\FA.\?.\?.\?.\?.\?.\?.\?.\?\FA|\FB.\?.\?.\?.\?.\?.\?.\?.\?\FB|\FC.\?.\?.\?.\?.\?.\?.\?.\?\FC|\FD.\?.\?.\?.\?.\?.\?.\?.\?\FD|\FE.\?.\?.\?.\?.\?.\?.\?.\?\FE|\FF.\?.\?.\?.\?.\?.\?.\?.\?\FF)" }
:if ([:len [find name=skypetoskype]] > 0) do={ :put "already have skypetoskype" } else={ add name=skypetoskype regexp="^..\02............." }
/ip firewall mangle
add action=mark-connection chain=prerouting comment="" disabled=no layer7-protocol=skypeout new-connection-mark=skype-conn passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no layer7-protocol=skypetoskype new-connection-mark=skype-conn passthrough=yes
add action=mark-packet chain=prerouting comment="" connection-mark=skype-conn disabled=no new-packet-mark=skype-flow passthrough=no
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
shadowskippie
Re: NV2
Wed Mar 09, 2011 2:45 pm
Ya ill tell you how it works when i get to it
right now i have few other pressing issues that need to be attendedto before i can start experimenting and even then ill need to wait a bit till after i have fixed things and the waters have calmed :lol:
other wise the client will skin me for the fun of it
Users browsing this forum: martinclaro, sjafka and 37 guests
