1nOnlyShaikh
How to Create Manual Queue????
Sun Jun 05, 2011 11:08 pm
Hello Mates,
may any body please tell me how to create manual queues ?
Thanks in Advance
Regard's
Shaikh
1nonlyshaikh@gmail.com
ditonet
Forum Veteran
Forum Veteran
Re: How to Create Manual Queue????
Mon Jun 06, 2011 1:27 am
Here is an example of my 'manual queue':
As you can see, Ubuntu has priority over FreeBSD at the moment.
You can make your own 'manual queue' by putting manuals on your desk, one by one.
Queue lenght depends on your desk size :D .
And now a little more seriously, in RouterOS are 'Simple Queues' and 'Queue Tree', 'manual queue' doesn't exists.
So RTFM and Wiki before you ask question.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
Toiletbowl
Mon Jun 06, 2011 4:49 pm
HTH,
i want that book :D
1nOnlyShaikh
Mon Jun 06, 2011 11:52 pm
HTH,
Thanks a Lot for your KIND and Detailed Reply.
Yes i want to know about "Queue Tree" or what you will suggest for static ip?
Regard's
Shaikh
ditonet
Forum Veteran
Forum Veteran
Tue Jun 07, 2011 12:24 am
I'm not sure that I understood you correctly.
If you want to shape traffic for one static IP address in your network 'Simple Queue' is OK.
But if you want to shape traffic for eg. 100 users (every with static IP) then "Queue Tree' is a must.
Queue Tree gives you ability to shape hundreds of users with one queue rule using PCQ.
With queue tree is also possible to make double-queueing,
it means that you are able to shape traffic per-user and per-service simultanously.
Carefully read Wiki manual about queues http://wiki.mikrotik.com/wiki/Manual:Queue
Make some test how it works, if you don't have a lab, it's quite safe to test queues even in production enviroment.
HTH,
1nOnlyShaikh
Tue Jun 07, 2011 1:50 am
HTH,
Thanks Buddy for your quick response.
Regard's
Shaikh
petrn
Tue Jun 07, 2011 3:29 am
amazing
Petr
Users browsing this forum: nalev22 and 26 guests
