MasterofDisaster
Usermanager Database, ....
Fri Jul 01, 2011 8:54 pm
... it's possible to combine two or more usermanager databases into one?
How can I do this?
gmsmstr
Trainer
Trainer
Re: Usermanager Database, ....
Fri Jul 01, 2011 11:40 pm
Would assume you would just do it in the command line, by exporting data from one and importing it into the other. Don't know if the payment history and logs would carry over.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
dssmiktik
Forum Veteran
Forum Veteran
Sat Jul 02, 2011 8:59 am
Not with RouterOS tools, however it may be possible using and sqllite file reader/modifier, then merging the table(s).
NOTE: I have not tried this, and cannot confirm this works.
Doug
MasterofDisaster
Sat Jul 02, 2011 1:57 pm
Ok thank you. I would test it...
MasterofDisaster
Sat Jul 02, 2011 7:55 pm
It dont work. There are some other possibilitys?
dssmiktik
Forum Veteran
Forum Veteran
Sun Jul 03, 2011 2:46 am
MasterofDisaster,
As previously mentioned, I have not tried it myself, but I may be able to provide some pointers to head you in the right direction.
What exactly have you tried so far?
Doug
laithmikrotik
Sun Jul 03, 2011 9:11 am
why you want to do this step.exactly ?
I LIKE MIKROTIK
MasterofDisaster
Sun Jul 03, 2011 6:08 pm
Because we are a little ISP and have more then on authentication "servers" like mikrotik.
We would combine all of it, because so we have a simpler management and would not upgrade an check lots of devices
Users browsing this forum: No registered users and 24 guests
