I have a simple antenna questions with maybe not so simple answers. Please help.
1. Between two 5.4Ghz GRID parabola antennas with both having 21dBi gain the better antenna is the one with bigger grid?
Does the fact that they both have 21dBi gain make them comparable in performance?
2. Patch antenna vs grid parabola antenna (both having the same gain).
Is it OK to say that one performs better than the other (bot having the same gain)?
3. Does the size of the patch antenna panel have any influence on the performance (SNR ratio for example).
Thank you for helping.
