MUM Europe 2020
CDX54
Route a single address
Thu Dec 01, 2011 4:11 am
I have a /28 block of public addresses and need to route some of them to internal routers. This is the topology:
x.177(cable modem)----x.178(mikrotik)---bridged network(on port ether2)---here is where I want to put x.y (x.179) on another mikrotik router.
How can I route a single public address without sub-netting, and losing half the addresses, my /24 block...
Thanks so much.
CW
pedja
Long time Member
Long time Member
Re: Route a single address
Thu Dec 01, 2011 8:43 am
You cannot rute without subnetting. You may use dst-nat instead.
dasiu
Trainer
Trainer
Thu Dec 01, 2011 8:51 am
Trying to understand... Where is the /28 subnet? Does the cable modem also have an IP address from the same /28 subnet? What is the gateway for the /28 addresses - is it still your device, or your provider's?
x.178 - is it configured in the same time on the mikrotik connected to gateway AND on "another mikrotik router"? (that's what diagram says...)
x.176 - is it IP address configured on cable modem?? x.176/28 is network address, not a device address. You have x.177-x.190 possible addresses
Or - in other words - is the /28 IP pool ROUTED to your network through DIFFERENT IP address on WAN?
If it is routed - You can try to route /32 address - by creating a PPP address (on first Mikrotik on ether2: address=192.168.0.1/32 network=x.178, on other Mikrotik: address=x.178/32, network=192.168.0.1)
If it is switched (the /28 is on WAN) - I would just bridge it through a vlan or vpls between the MTs.
CDX54
Fri Dec 02, 2011 6:41 am
dasiu,
Thank you for your reply. First things first, I corrected the diagram:
(The gateway / cable modem is x.177, the second router should have been x.179 the next address in the block)
Next, as above the gateway is x.177, after reading through your post I realized my error. So when I entered it into the main mikrotik as such it shows up as a /32 not /28. Don't know if this helps any.
;;; WAN Public
-D		x.x.x.178/32	x.x.x.177	ether1-gateway
My usable address range is x.178-x.190 as per my ISP.
Now on the first question you have about the cable modem, it appears that its address is x.177 as when I tracert from the mikrotik in the above diagram to a server connected directly to the second port on the cable modem it goes hop 0 = x.177 hop 1 = x.180
The gateway is my providers near as I can tell. Which from what I understand you saying that means it is routed and I should be able to route /32 addresses out to other devices (routers, servers, etc)?
Thank you so much again, I am really starting to like networking / routing but it is kicking my behind trying to wrap my head around some of the concepts.
CW
CDX54
Wed Dec 07, 2011 1:45 am
I ended up just doing 1 to 1 nat for each address to an internal address. Works fine so far.
CW
Users browsing this forum: No registered users and 32 guests
