skoenman
load balancing not working
Thu Dec 01, 2011 1:29 pm
Hallo guys i have a problem were i have been trying to get my load balancing going between 2 ADSL routers but i cant seem to get the settings to work correctly. from the mikrotik i can ping all surroundings but from my pc i cant ping internet ??? i can ping local interface on mikrotik.
Tutorial i followed was http://wiki.mikrotik.com/wiki/Manual:PCC
i have a idea it might have something to do with routing ....attached is screenshots of what this looks like and what my dns looks like.
i have a bridge connection which the moment i enable it the internet works but then the connection markings dont???
ditonet
Forum Veteran
Forum Veteran
Re: load balancing not working
Thu Dec 01, 2011 1:58 pm
Do everything as is exactly described in mentioned example and check if it works.
Next make your 'improvements' like "Local' and 'Wan1' interfaces in the same subnet :D
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
skoenman
Thu Dec 01, 2011 10:12 pm
OK guys after sitting for 3 days with this i figured it out....jippy. One needs to have the 2 wan interfaces and the lan interface on diffrent ip ranges . this enables you to route the traffic correctly.
Thanks for help.
Users browsing this forum: No registered users and 12 guests
