cursols
How to access mikrotik/winbox from different ip location
Thu Dec 08, 2011 11:09 am
I am in Pakistan using mikrotik 3.3 . I have two DSL lines which are connected with RB750 for load balancing. I am unable to access winbox from other network. I can not access my network while sitting in other city/network. Kindly guide me how can I make setting.
Thank you.
Muhammad Fawad
bmorton
Re: How to access mikrotik/winbox from different ip location
Thu Dec 08, 2011 11:02 pm
As long as it's not behind a firewall or connecting via a VPN, all you should need is the public IP of the box you want to connect to.
hackersmooth88
Fri Dec 09, 2011 12:31 pm
Thank you.
Muhammad Fawad
1. You must install VPN Server .. Easy you install pptp Server
2. Rule your firewall allow pptp
conquerer
Fri Dec 09, 2011 12:50 pm
Set your modem in bridge mode and configure PPPOE in Mikrotik.
you must have a real / live IP on WAN1.
Then only you can connect your server from anywhere from the world.
Regards.
cursols
Fri Feb 17, 2012 7:39 am
Regards.
Please guide me furthers I am new in this field. Is it possible to give me some time so that I may be able to show the system via team viewer.
Thank you.
harisagars
Fri Feb 17, 2012 2:12 pm
you need public ip first to access from every where ask your isp for public ip
cursols
Fri Feb 17, 2012 4:47 pm
Yes I have public IP
KbzA
Mon Feb 20, 2012 3:33 pm
1st- Only if your public ip is dynamic, you need script for update every ip changed. See wiki
2nd- You need forward port in Firewall/NAT
Users browsing this forum: No registered users and 15 guests
