insMikrotik
How to enable SNMP?
Tue Dec 13, 2011 1:39 pm
Hi all,
I have installed Mikrotik 5.9 (trial version for 24 hours),
i want to enable the SNMP service , can any one tell me the procedure how to enable the SNMP service ????
and How should i check whether SNMP service is enabled or not ????
dasiu
Trainer
Trainer
Re: How to enable SNMP?
Tue Dec 13, 2011 2:41 pm
/snmp print - and look if it is enabled or not :)
/snmp set enabled=yes - enables SNMP
/snmp community print - shows, what SNMP communities you have. By default it is "public" with read-only access from all IP addresses (0.0.0.0/0)
Then - you can just run snmpwalk to the IP address of your MikroTik - and see what values are available :).
insMikrotik
Tue Dec 13, 2011 2:52 pm
@dasiu, thanks for ur reply,
i have done same thing but when seen in
/ip services it is not showing the snmp service enabled .
[sudhir@MikroTik] /ip service> print
# NAME PORT ADDRESS CERTIFICATE
0 telnet 23
1 ftp 21
2 www 80
3 ssh 22
4 X www-ssl 443 none
5 api 8728
6 winbox 8291
Here i should get SNMP enabled right ????
but i dint get !!
dasiu
Trainer
Trainer
Tue Dec 13, 2011 3:35 pm
No, you don't set snmp in /ip services. Probably because SNMP uses UDP, and in /ip services - you have TCP ports, that are open :). Just /snmp set enabled=yes - and that's all!
insMikrotik
Wed Dec 14, 2011 6:07 am
Hi dasiu,
[sudhir@MikroTik] > /snmp print
enabled: yes
contact:
engine-id:
trap-community: public
trap-version: 1
It is showing enabled for me .......
But when i tried to connect it through the SNMP Managers like Mrtg and other SNMP Managers i was unable to connect to it ..... I was getting request timed out exceptions ...
Would u plz help me regarding that ....
dasiu
Trainer
Trainer
Wed Dec 14, 2011 12:43 pm
Please, show us your:
/ip firewall filter print
(and what ROS version are you using?)
insMikrotik
Wed Dec 14, 2011 2:27 pm
Hi dasiu,
Thanks for ur reply ....
i got the problem ....
in this initially i gave address as my router ip ....
but when changed to 0.0.0.0/0
[sudhir@MikroTik] > /snmp community print
# NAME ADDRESS SECURITY READ-AC
0 public 0.0.0.0/0 none yes
its working fine .....
Any way thank U very much ... :D
normis
Wed Dec 14, 2011 3:17 pm
dasiu
Trainer
Trainer
Wed Dec 14, 2011 3:52 pm
Hi dasiu,
That's good :)
You should look more carefully on my first response in this topic - you had the solution already there :)
ElvisLeon
Wed Aug 26, 2015 6:50 pm
Hi
I did the previous process and I cant connect the Dude to device .
The dude is my pc and the devices are on various places in my country. I connect the devices trough of public IPs. and I think that firewall dont leaves connect the dude .
I wanna connect trough SNMP for monitoring the devices.
I will tankful with your responses
hnoor0033
Fri Apr 01, 2016 10:15 am
very nice
amiraghdam
Sun Feb 25, 2018 8:37 pm
hi can i help me about enable SNMP in mikrotik CCR1016-12s -1s+ . it is possible but i need to get parameters values in SFP modules as TX power & RX power & wavelengths and etc... but every OID can i get the value but i can not get SFP values when i get it on OID's MIB. how can i solve it ??? what is problem ??? please help me thanks....
Users browsing this forum: Bing [Bot], zenkokagami and 37 guests
