cyph3r
PCC ISSUE 3 WAN
Fri Jan 20, 2012 12:25 pm
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.4.4,8.8.8.8
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN3
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
this configuration is not working well
the load is not balanced properly !!!!!
Is there any error in my config ???
Regards,
Mehmood Ahmed |ĉУρĤ3г|
(+92)345-2835810
www.adminsline.com
adminsline.wordpress.com
E-mail: admin [at] adminsline.com
cyph3r
Re: PCC ISSUE 3 WAN
Sat Jan 21, 2012 11:47 am
is there any one ???????????????????
Regards,
(+92)345-2835810
www.adminsline.com
armanalam
Re: PCC ISSUE 3 WAN
Sat Jan 21, 2012 3:37 pm
your configuration is all right .... no problem at all ....
huigezi
Re: PCC ISSUE 3 WAN
Sun Jan 22, 2012 4:52 am
Need not be in such trouble
use the code can set all configuration
:global adsl     “9”
:global address  “172.168.1.0/24”
/interface pppoe-client
:for a from=1 to=$adsl do= {add add-default-route=no dial-on-demand=no use-peer-dns=no name=("pppoe-out".$a) user=$a password=$a interface=(“ether”.($a+1)) }
/ip firewall mangle
:for a from=1 to=$adsl do={
add action=mark-connection chain=prerouting dst-address-type=!local src-address=$address passthrough=yes new-connection-mark=(“c-“.$a) per-connection-classifier=("both-addresses:”.$adsl.”/".($a-1)) comment=(“pcc-“.$a);add action=mark-routing chain=prerouting src-address=$address passthrough=yes connection-mark=(“c-“.$a) new-routing-mark=(“r-“.$a)}
/ip firewall mangle
:for a from=1 to=$adsl do={add chain=input action=mark-connection new-connection-mark=(“c-“.$a) in-interface=("pppoe-out".$a) comment=("in-out-".$a);add chain=output connection-mark=("c-".$a) action=mark-routing new-routing-mark=("r-".$a) passthrough=no}
:for a from=1 to=$adsl do={add action=masquerade chain=srcnat out-interface=("pppoe-out".$a) src-address=$address disabled=no comment=$a}
:for a from=1 to=$adsl do= {add check-gateway=ping gateway=("pppoe-out".$a) routing-mark=("r-".$a) comment=("r-".$a);add check-gateway=ping distance=$a gateway=(“pppoe-out”.$a)}
If you want knowledge, you must toil for it
cyph3r
Re: PCC ISSUE 3 WAN
Sun Jan 22, 2012 6:11 pm
huigezi your script is not working !!!
my conf
WAN1 = 4mb
WAN2 = 4mb
WAN3 = 4mb
Local = Lan
web sessions is breaking, i have to press enter 2 time then it will open the web site !!!!!
Regards,
(+92)345-2835810
www.adminsline.com
gtpro
Re: PCC ISSUE 3 WAN
Sun Jan 22, 2012 7:13 pm
Hi, dont use both addresses and ports, use both addresses ONLY. Try it!
cyph3r
Re: PCC ISSUE 3 WAN
Thu Jan 26, 2012 1:02 pm
thanks gtpro
i will try it !!
Regards,
(+92)345-2835810
www.adminsline.com
Users browsing this forum: cokiere, hasiosznup, SoTech57 and 46 guests
