junkie
Upgrade problem
Tue Jan 24, 2012 6:05 pm
maybe this isn't a right place for this post but ... i'm trying to install RouterOS 5.12 on a goove without any result.
i started from the 5.2 for passing directly to the 5.12, but nothing, so i've tryed from 5.11 to 5.12 (upgrading the fw before), and nothing again. (with 2 machines)
I also noted that version 5.12 is recognized in a different way from the 5.11 , as shown in the figure :
It's normal?
Is there any workaround to installing 5.12 on groove?
cbrown
Trainer
Trainer
Re: Upgrade problem
Wed Jan 25, 2012 2:37 pm
Nope. Upload the file and reboot the device. I would try to upload the 5.12 package again because it should show up as a package. How are you trying to upgrade?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
normis
Re: Upgrade problem
Wed Jan 25, 2012 3:15 pm
you are connected via MAC address. very bad idea. connect to IP address and it will work.
junkie
Re: Upgrade problem
Thu Jan 26, 2012 11:31 am
i'm going to try
Users browsing this forum: WondiW and 99 guests
