MUM Europe 2020
poznavatelj
MikroTik - uTorrent behing NAT does not work
Mon Jan 30, 2012 10:51 pm
uTorrent does not make any connection through MikroTik RB751U-2HnD.
I have disabled NAT-PMP and uPnP in uTorrent, and I select one single port 42056.
On router I have srncat masquerade on Out Interface.
Maybe someone have advice about such a topic like MikroTik-uTorrent behing NAT.
THX
changeip
Re: MikroTik - uTorrent behing NAT does not work
Mon Jan 30, 2012 11:16 pm
just open port 42056 (udp/tcp) to your internal ip and it should work. dstnat rule inbound ...
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
poznavatelj
Tue Jan 31, 2012 7:10 am
I have dynamic IPs (DHCP)
I have tried rules 0 and 1, but still nothing is better.
NAT:
0 chain=dstnat action=dst-nat to-ports=42056 protocol=udp in-interface=ether1-gateway src-port=42056 dst-port=42056
1 chain=dstnat action=dst-nat to-ports=42056 protocol=tcp in-interface=ether1-gateway src-port=42056 dst-port=42056
2 ;;; default configuration
chain=srcnat action=masquerade out-interface=ISPname
THX
poznavatelj
Tue Jan 31, 2012 2:02 pm
I found the solution. :)
THX
changeip
Tue Jan 31, 2012 6:41 pm
yep - just remove src-port=42056 from the rules you posted.
troy
Sun Feb 05, 2012 6:35 pm
Dunno what solution you found, but here's my setup:
/ip upnp
set allow-disable-external-interface=no enabled=yes
/ip upnp interfaces
add interface=wan type=external
add interface=lan type=internal
I get lots and lots of dynamic nat rules from utorrent and other applications. Works a treat!
tournet
Wed Feb 26, 2014 5:25 am
I encounter the same problem.
My wan connection is PPPOE
lan gateway is 192.168.0.1
internal client's IP address is 192.168.0.223
the utorrent use port 56667, here is my nat config for utorrent.
    add action=dst-nat chain=dstnat comment=utorrent dst-address=\
    !192.168.0.1 dst-port=56667 protocol=tcp src-address=!192.168.0.0/24 \
    to-addresses=192.168.0.223 to-ports=56667
but the utorrent tells " Port is not open (you are still able to download)", what the problem of this nat config?
BTW, I don't want to use upnp.
francisuk24
Mon Mar 31, 2014 4:37 am
Im using transmission on ubuntu with port 51413 and says that is Open when you go to click it.
add chain=dstnat action=dst-nat to-addresses=192.168.1.3 to-ports=51413 protocol=tcp dst-port=51413
/ip upnp
/ip upnp interfaces
using UPnP can be a security risk but then again so is torrents lol ;)
RouterBoard RB750R2, RouterOS Level 4
ISP: Zen Internet via VDSL 2 > 74.68Mb Down / 17.84Mb Up
badmojorayman
Wed Apr 20, 2016 12:54 am
My router is now running 6.34.2 and none of these settings work. Did they change "wan" and "lan" to another set of words?
Sob
Wed Apr 20, 2016 1:28 am
Intead of "wan" and "lan", use real names of your interfaces, e.g. "wlan1" or "ether1".
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Users browsing this forum: dejoebad, nowinskit and 45 guests
