hawkeye000
Block all websites except few and allow other for some users
Fri Mar 09, 2012 10:19 pm
Please help me
I want to Block all websites except a few for some users and allow other to browse all net
tws101
Re: Block all websites except few and allow other for some u
Sat Mar 10, 2012 12:22 am
hawkeye000
Sat Mar 10, 2012 7:28 am
thanks dear
I can't do it for my issue
Just i want to do :
1-Block all web sites except 30 for 10 users
2-Redirect which blocked to my company site
3-allow all web sites for another 5 users
I tried to use firewall .. layer7 .. web proxy .. but i faild :(
JP_Wireless
Sat Mar 10, 2012 9:24 am
thanks dear
Just i want to do :
You want to allow 30 websites for 10 users and give unlimited access to 5? what of other users? what wil they be doing on ur network?
Is it possible to seperate them using ip address, if yes, you can create firewall rule with the ip's.
you will use webproxy access to redirect all users to ur company website.
JP Wireless:::
One Stop ICT, Alternative Power & Electronics Securities Solutions Provider!
Tel: +2348098798779, +2348055353151
http://www.jpwireless.net: Email: info[at]jpwireless.net
36, Diya Road, Gbagada, Lagos - Nigeria.
perspetolis
Sat Mar 10, 2012 4:55 pm
hi
you can all your request with web proxy
The MikroTik RouterOS implements the following proxy server features:
1.Regular HTTP proxy
2.Transparent proxy. Can be transparent and regular at the same time
3.Access list by source, destination, URL and requested method
4.Cache access list (specifies which objects to cache, and which not)
5.Direct Access List (specifies which resources should be accessed directly, and which - through another proxy server)
6.Logging facility
for more help : http://www.mikrotik.com/testdocs/ros/3.0/pnp/proxy.php
Mohsen Farahani
MTCNA-MTCWE-MTCTCE
http://www.ipsolution.ir
hawkeye000
Mon Mar 12, 2012 10:35 am
dear JP_Wireless
This for example if i have 15 user on my network :D
Dear perspetolis
Web proxy worked with one IP not for a list
so in this case i will make 30 record for every IP - as dst.address for websites -
at final i will have more than 300 record ?????
tws101
Mon Mar 12, 2012 10:13 pm
I have web proxy setup right now restricting different vlans blocking entire ranges. 192.168.3.0/24 for example.
hawkeye000
Tue Mar 13, 2012 8:02 am
Dear tws101
Please tell me how can i do that !!!
I enabled web proxy and deny one IP for dst.address *.* but it still browse every thing :shock:
and i can't login to winbox until restarting the routerboard !!!
tws101
Wed Mar 14, 2012 4:25 pm
Try denying all that is NOT your allowed ones. See if that works.
hawkeye000
Wed Mar 14, 2012 10:51 pm
Same thing web proxy doesn't work at any case :shock:
mardawe
Wed Mar 14, 2012 11:17 pm
dear..
1-if you want to put an ip address that you don't wanna to add this rule to him(with the ! mark)
2-the URL that you want to BLOCK
3-if you want to block a pic. or a type of file
4-you know it for sure.
5-put the url you want to redirect the user to it ,when the user opend a website or a pic that you blocked.
if you want to redirect the user to a page in the server just add the address of it.for example:
(your-servers-name).net/hotspot/access_blocked.html
i hope you'll get use of these information
MahmouD KhuffasH
PALESTINE
share your experience
tws101
Wed Mar 14, 2012 11:41 pm
Are you setup like this
http://wiki.mikrotik.com/wiki/How_to_Bl ... sing_Proxy
That is working for me. Anything I block gets blocked.
hawkeye000
Thu Mar 15, 2012 9:22 am
Mr mardawe
So i wanna block 30 websites for 10 users .. i have to do this step 300 times ???
hawkeye000
Sat Mar 17, 2012 11:33 pm
up??????????
tws101
Mon Mar 19, 2012 4:56 pm
hawkeye,
Just block the IP range and do it 10 times.
Users browsing this forum: No registered users and 73 guests
