Kernellinux
Port Forward Lotus Notes / Domino
Thu May 24, 2012 7:06 am
I've tried searching the forum as well as Good with no luck here is my problem...
I am simply trying to forward port 1352 from the outside world into my server.
When I'm on the lan it connects fine locally.
I have checked with the Lotus Notes / Domino community and they assure me that the only thing required for a notes connection is 1352 to be forwarded to the server.
Can anyone see what I'm doing wrong here?
 0   ;;; default configuration
     chain=srcnat action=masquerade out-interface=ether1-gateway
 1   chain=dstnat action=dst-nat to-addresses=192.168.0.1 to-ports=80
     protocol=tcp dst-address=96.XX.XX.XX dst-port=80
 2   chain=srcnat action=masquerade protocol=tcp src-address=192.168.0.0/24
     dst-address=192.168.0.1 out-interface=bridge-local dst-port=80
 3   chain=dstnat action=dst-nat to-addresses=192.168.0.10 to-ports=2230
     protocol=tcp dst-address=96.XX.XX.XX dst-port=2230
 4   chain=dstnat action=dst-nat to-addresses=192.168.0.20 to-ports=2220
     protocol=tcp dst-address=96.XX.XX.XX dst-port=2220
 5   chain=dstnat action=dst-nat to-addresses=192.168.0.19 to-ports=2221
     protocol=tcp dst-address=96.XX.XX.XX dst-port=2221
 6   chain=dstnat action=dst-nat to-addresses=192.168.0.15 to-ports=1352
     protocol=tcp dst-address=96.XX.XX.XX dst-port=1352
Thanks in advance! If anyone is using a RouterOS and Domino and it worked please chime in, I will at least know it's something specific to me.
GuJack20
Trainer
Trainer
Re: Port Forward Lotus Notes / Domino
Thu May 24, 2012 1:21 pm
Try to remove out-interface=ether1-gateway from the masquerade rule
--Do you remember that guy who gave up? Neither does anybody else!
Kernellinux
Thu May 24, 2012 7:17 pm
Thanks for your quick reply. I will try that as soon as I get back to my office. I'm always eager to learn the why in addition to the what could you explain why that is the problem?
Users browsing this forum: No registered users and 31 guests
