David1234
is it possible to know which websites entered in Hotspot?
Tue May 29, 2012 11:09 am
I'm using hotspot in a school , and I want to make sure no one is entering bad sites.
and also to know if someone is trying to enter the RB.
I know I can block in the firewall , but we all know there is 100000000 sites.
I don't want or need to know how is surfing , just where they serf?
possible?
I don't need to do this for spying. just for security.
Thanks ,
Feklar
Re: is it possible to know which websites entered in Hotspot
Tue May 29, 2012 7:02 pm
The best option you are likely going to use in that situation is a dedicated proxy server that will be able to do content filtering, and logging of the HTTP requests. Trying to properly handle and process this on a layer3 device really won't work to well. It will require too much CPU power, and will miss a lot of content that you either want to log or block.
For logging and protecting the router, setting up appropriate firewall rules will be your best bet there as well. You can set up a logging action to keep track of the attempts if any, and then right after that drop the traffic.
marioclep
Trainer
Trainer
Wed May 30, 2012 12:02 am
You can use webproxy and a logging rule (webproxy, !debug) to see which sites are being used.
Regards
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
David1234
Wed May 30, 2012 5:11 pm
about the option of the webproxy
will it "kill" the router? or the free disk? I'm using RB411
and do you know how do I define it?
thanks ,
Feklar
Wed May 30, 2012 5:28 pm
If you are going to use the built in proxy on a 411, it might be a bit much for it to handle depending on the number of clients just from a CPU standpoint. You don't need to store any files locally for a proxy, so it won't necessarily thrash a disk, but it will generate a ton of logs, so you will want a dedicated syslog server if nothing else. The built in proxy is also not necessarily as capable as a full featured proxy like squid is for content filtering and other services, and you could still run a logging server on proxy server.
skot
Long time Member
Long time Member
Fri Jun 01, 2012 7:39 am
Can you post rules on how to do this? Thanks.
I don't need any karma... I have Ιησους Χριστος!
rodolfo
Long time Member
Long time Member
Fri Jun 01, 2012 3:08 pm
or you can enable ip accounting and use the cgi inside webserver to get log
ip accounting traffic-accounting enable
enable web service then load the log calling http://routerIP/accounting/ip.cgi
rodolfo
IZ0UQV
imrankosi
Mon Jun 04, 2012 8:12 am
hi,
Its possible to view and save the log file of the user (what they did on internet ). use web proxy, and nat setting and software to recive the logs .
David1234
Wed Jun 06, 2012 9:31 am
I will try it.
I thought it will be easier to do - but I will try and see what happened.
Users browsing this forum: No registered users and 16 guests
