MUM Europe 2020
Jeffrey06
Simple Wireless AP Setup
Fri Oct 19, 2012 2:20 am
I need a basic guide to setup my MikroTik just for a wireless router for my guests.
I have my DSL Modem that has a default gateway of 192.168.0.1
I'm wanting to give my Mikrotik a IP of 192.168.1.200, then assign IP's via DHCP for 192.168.1.x for my guests.
Here is what I have, I can connect and Win 7 DOESN'T give me the "Limited or No Connectivity Message" but I'm unable to open any webpage. Also, I'm unable to ping 192.168.0.1
I'm also unsure for the DHCP Client. Should I configured for the WAN or the LAN?
I've attached a screen of my setup, any help would be appreciated.
cbrown
Trainer
Trainer
Fri Oct 19, 2012 2:27 am
Please post /export compact
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Jeffrey06
Re: Simple Wireless AP Setup
Fri Oct 19, 2012 3:11 am
[admin@MikroTik] > export compact
# jan/02/1970 01:15:57 by RouterOS 5.14
# software id = FW4M-101H
/interface wireless
set 0 band=2ghz-b/g disabled=no frequency=2412 l2mtu=2290 mode=ap-bridge \
wireless-protocol=802.11
add name=dhcp_pool1 ranges=192.168.0.1-192.168.0.254
add name=dhcp_pool2 ranges=192.168.1.0-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=ether1 name=dhcp_server1
add address-pool=dhcp_pool2 disabled=no interface=wlan1 name=dhcp_server2
add address=192.168.0.200/24 interface=ether1
add address=192.168.1.1/24 interface=wlan1
add address=192.168.1.1/32 gateway=192.168.0.1
[admin@MikroTik] >
Jeffrey06
Fri Oct 19, 2012 4:55 am
Also, here is another export (my latest)
 [admin@MikroTik] > /ip address print detail
 0   address=192.168.0.200/24 network=192.168.0.0 interface=ether1
     actual-interface=ether1
 1   address=192.168.1.1/24 network=192.168.1.0 interface=wlan1
     actual-interface=wlan1
 2 D address=192.168.0.11/24 network=192.168.0.0 interface=ether1
[admin@MikroTik] > /ip route print detail
 0 ADS  dst-address=0.0.0.0/0 gateway=192.168.0.1
        gateway-status=192.168.0.1 reachable via  ether1 distance=0 scope=30
        target-scope=10 vrf-interface=ether1
 1 ADC  dst-address=192.168.0.0/24 pref-src=192.168.0.200 gateway=ether1
        gateway-status=ether1 reachable distance=0 scope=10
 2 ADC  dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=wlan1
        gateway-status=wlan1 reachable distance=0 scope=10
[admin@MikroTik] > /interface p
ppp-client  pppoe-client  pptp-client  print
ppp-server  pppoe-server  pptp-server
[admin@MikroTik] > /interface print detail
 0  R  name="ether1" type="ether" mtu=1500 l2mtu=1526 max-l2mtu=1526
 1     name="ether2" type="ether" mtu=1500 l2mtu=1522 max-l2mtu=1522
 2     name="ether3" type="ether" mtu=1500 l2mtu=1522 max-l2mtu=1522
 3  R  name="wlan1" type="wlan" mtu=1500 l2mtu=2290
[admin@MikroTik] > /ip pool print detail
 0 name="dhcp_pool1" ranges=192.168.0.1-192.168.0.254
 1 name="dhcp_pool2" ranges=192.168.1.0-192.168.1.254
[admin@MikroTik] > ip dhcp-server export
# oct/18/2012 20:53:04 by RouterOS 5.14
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static \
    disabled=no interface=ether1 lease-time=3d name=dhcp_server1
add address-pool=dhcp_pool2 authoritative=after-2sec-delay bootp-support=static \
    disabled=no interface=wlan1 lease-time=3d name=dhcp_server2
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.1.1/32 dhcp-option="" dns-server="" gateway=192.168.1.1 \
    ntp-server="" wins-server=""
[admin@MikroTik] > /ip dhcp-server print detail
 0   name="dhcp_server1" interface=ether1 lease-time=3d address-pool=dhcp_pool1
     bootp-support=static authoritative=after-2sec-delay
 1   name="dhcp_server2" interface=wlan1 lease-time=3d address-pool=dhcp_pool2
[admin@MikroTik] > /ip firewall export
# oct/18/2012 20:53:29 by RouterOS 5.14
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
    10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
    udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
    disabled=yes
    disabled=yes
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
[admin@MikroTik] >
deejayq
Fri Oct 19, 2012 10:43 am
you should set a src-nat masquerade rule for clients coming from wlan
delete dhcp_pool1, you don't need it
delete dhcp_server1, you don't need it
dhcp-server network should be something like address 192.168.1.0/24 gateway=192.168.1.1 also include some dns servers here
set and ip route to destination 0.0.0.0 gateway 192.168.0.1 (assuming 192.168.0.1 is the gateway that you see if you were to connect directly to DSL modem.
i don't know much about wireless modes, but i think it has to be mode=ap and not mode=ap-bridge
Jeffrey06
Fri Oct 19, 2012 8:58 pm
Thank you for the help, but still no luck. When I first connect my Laptop to the network it looks fine, after I try to go to a webpage it will time out and I let the "Limited or No Connectivity" error icon on my Wireless.
Here is my latest print..
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 5.14 (c) 1999-2012       http://www.mikrotik.com/
 1   S  dst-address=0.0.0.0/0 gateway=192.168.0.1
        gateway-status=192.168.0.1 reachable via  ether1 distance=1 scope=30
        target-scope=10
 2 ADC  dst-address=192.168.0.0/24 pref-src=192.168.0.200 gateway=ether1
 3 ADC  dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=wlan1
 0 name="dhcp_pool2" ranges=192.168.1.0-192.168.1.254
[admin@MikroTik] > /ip dhcp-server export
# oct/19/2012 12:56:55 by RouterOS 5.14
add address=192.168.1.0/24 dhcp-option="" dns-server=192.168.0.1 gateway=\
    192.168.1.1 ntp-server="" wins-server=""
 0   name="dhcp_server2" interface=wlan1 lease-time=3d address-pool=dhcp_pool2
# oct/19/2012 12:57:16 by RouterOS 5.14
    disabled=yes
add action=masquerade chain=srcnat disabled=no dst-address=192.168.0.1 \
    src-address=192.168.1.0/24 src-address-type=""
[admin@MikroTik] >
Jeffrey06
Fri Oct 19, 2012 9:34 pm
Anybody willing to help out..
I can ping 192.168.0.1 and 192.168.1.1 while on the network from my Computer, however, I just can't access any pages. It's something to do with my DNS or probably my NAT. Any guidance with those?
Now, if I ping from the MikroTik for 192.168.0.1 it timesout. I can ping 192.168.1.1 with success
Jeffrey06
Fri Oct 19, 2012 9:56 pm
I got it. I needed to setup the "Bridge" and that was it. I can now browse the internet.
Users browsing this forum: negr0, Sob, Zacharias and 55 guests
