MUM Europe 2020
jefben
Default Route Interface
Sun Nov 04, 2012 5:14 pm
I configured the default route using Winbox >IP Route and click apply.
This activate the correct interface(ethernet2) connected to the ISP router.
After rebooting the default route points to another ethernet interface(ethernet1).
How do I bind the default route to the specific interface-ethernet2??
deejayq
Re: Default Route Interface
Mon Nov 05, 2012 9:20 pm
describe how you set the default route
mixig
Mon Nov 05, 2012 9:51 pm
what is on ethernet 1? maybe you get default route from antoher side of eth1, maybe ether 2 is not running yet after reboot... do ip route print and c/p
jefben
Tue Nov 06, 2012 4:09 am
the default route is set to point towards the next hop ip which is a cisco router connected to the internet(default gateway)
There is no connection to ethernet 1. Its just a lan port used to access the winbox via lan cable on site.
[admin@xxxx NAS] > ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, r - rip, o - ospf, b - bgp
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r x.x.x.129 1 ether2
1 DC x.x.x.128/25 r 0.0.0.0 0 ether2
2 DC x.x.x.128/25 r 0.0.0.0 0 ether1
7 DC 192.168.1.0/24 r 0.0.0.0 0 ether3
8 DC 10.1.1.0/24 r 0.0.0.0 0 ether1
deejayq
Tue Nov 06, 2012 10:52 am
2 DC x.x.x.128/25 r 0.0.0.0 0 ether1 should not be there
try this, with winbox:
Interfaces Menu, select the interface ether2, 'General Tab' change the 'Master Port' to none, assuming you have routerboard, if you have x86 this will not be available.
jefben
Wed Nov 07, 2012 10:38 am
Thanks.
I will try that out and keep you updated.
jefben
Fri Nov 09, 2012 9:38 am
I have made the relevant changes.. However, did not have the menu shown when i accessed using winbox.
removed the route as informed..so far so good.
Thanks!!
Users browsing this forum: No registered users and 37 guests
