Skylink2012
colocation server "webserver" behind mikrotik
Sun Nov 25, 2012 6:47 pm
internet >>> IP Public >>> Mikrotik >>> Webserver
202.1.xx.xx 202.1.10.xx 202.1.9.xx
202.1.xx.xx
how to do what the settings please help, I am new in mikrotik ??
sjwrick
Mon Nov 26, 2012 8:52 am
/ip firewall nat chain=dst-nat dst-address=publicipaddress action=dst-nat to-address=internalIpAddress
You can specify ports also thus limiting exposure. So if it is just a web server direct port 80 to the script by adding
protocol=tcp dst-port=80
Be sure to add the public ip to the WAN interface.
For outgoing traffic you need to NAT
/ip firewall nat chain=src-nat src-address=internalIPAddress action=src-nat to-addresses=publicIPAddress
Rick
Skylink2012
Re: colocation server
Wed Dec 12, 2012 8:56 pm
hello rick, thanks for the response that is given. I am currently experiencing a complicated problem. we could see from my attachment.
I need suggestion for dedicated server configuration and mikrotik RB, because my server flooding and DDOS attacks by others every minute. and i used centos for my webserver include cpanel inside
thank you for your help
Romi
Rick
wulfgard
Re: colocation server "webserver" behind mikrotik
Wed Dec 12, 2012 9:01 pm
if you are under DDOS firewalling will not help you
you can survive DDOS if
1) you have more bandwidth than attackers
2) you can handle more pps than attackers
3) your server can answer to all request
a way to mitigate DDOS against http services can be to use reverse proxying
like haproxy which can blacklist high threshold attempts to port 80 from specific IP
Thierry
System and Network Engineer
Mikrotik Trainer - MTCNA MTCRE
Official French Mikrotik Distributor
Users browsing this forum: sapphire112 and 49 guests
