Duduhandelman
Bridge firewall by eth
Tue Dec 11, 2012 12:00 pm
Hi All.
I would like to isolate group of servers inside a LAN without changing ip address or using a vlans.
All should be done by a layer 2 filtering.
I would like to create a bridge of 5 interfaces.
The security model should be as follow.
1. All interfaces should have access to servers on on eth1.
2. Non of the remaining 4 interface have access to the other 4.
While doing a firewall rule with input interface as bridge I can catch the traffic.
But I would like to catch the traffic on the input interface member of the bridge with no success.
Do you think it's possible?
Thank you
jgellis
Re: Bridge firewall by eth
Tue Feb 26, 2013 3:57 am
You are looking for the firewall filter switch "in-bridge-port" and "out-bridge-port". I think you might already have figured out most of the configuration, so perhaps you just need to examine the very last line in my example below.
settings set use-ip-firewall=yes
add name=bridge1
port add bridge=bridge1 interface=ether1
port add bridge=bridge1 interface=ether2
port add bridge=bridge1 interface=ether3
port add bridge=bridge1 interface=ether4
port add bridge=bridge1 interface=ether5
/ip firewall filter add chain=forward in-bridge-port=!ether1 out-bridge-port=!ether1 action=drop
- If I helped you solve your problem... I am now able to accept tax-deductible Karma donations!
Users browsing this forum: gfhahsvhj, Google [Bot] and 56 guests
